I have one Audiocodes MP118 8FXO media gateway, between PSTN and internal SIP PBX Freeswitch, when calling from PSTN to IP, in this case, FXO automatic dialing ext 5001 on SIP server which is supposed to play IVR prompt, the problem is 1) many times when PSTN calls get answered some random media inserted before the right IVR prompt
2) some times the IVR prompt got cut off for the initial part
Audiocodes MP118 setup with not registering with SIP server, early media disabled. I have no single issue when calling from any SIP phones inside the network to the ext 5001 which is a main IVR.
could you please shed some light on this as you guys are Audiocodes experts? Thanks,
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem. If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call. Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Was this helpful?
Yes
No
Popular Solutions for AudioCodes MP118 Analog Modem
I was asked to test a NVF200R modem at our Maui resort condo. Although advertised as plug-and-play,...
(More)
I was asked to test a NVF200R modem at our Maui resort condo. Although advertised as plug-and-play, it was obvious from the beginning that it was not. It quit feeding an internet signal every time the phone was plugged in. Tech Support suggested some fixes in the phone room. I hooked up again, feeding the internet signal into my Belkin router. The entire Oceanic broadband cable system crashed! And I am being blamed! Seems that ALL extension phones must be plugged into your modem using splitters, no other telephone plugs in the condo can be used, and DHCP has to be disabled on my router. Sorry for venting, but I ask you, How can you advertise your modem as plug-and-play. Could you live with these restrictions in a two bedroom condo? I think you need to go back to the engineering department and develop a foolproof system! I am done with the test!
MP-118/4fxs/4fxo when i go off hook on the fxs line I get a reorder tone.When I call the station it...
(More)
MP-118/4fxs/4fxo when i go off hook on the fxs line I get a reorder tone.When I call the station it rings and I can pick it up and I do have two-way talk path. Any ideas??
