Question about RCA P52960 52" Rear Projection Television
Bowed Picture This unit has a bowed (up) picture at the top and bottom and the sides bow out.
  • 7 more comments
  • M.G. Carlton Oct 06, 2008
    Yes, this is an RCA P52960 and the chassis # is a PTK-195Y06B. Yes, please supply additional details and instructions. Thank You
  • kmasb Oct 14, 2008
    Bowed picture
  • digitaldvant Oct 21, 2008
    I have the same convergence problem...and I would LOVE to do this myself, as I can solder with the best of them. I have been using this t.v. for about 7 months now, and a relative used it since it was new. I got it with the convergence problem, but now out of nowhere I went to turn it on, there is nothing. I hear 3 high pitch squeals, and then nothing. I took the backing off to get to the chassis to hear where it is coming from, and it seems to be coming from a large white cylindrical part near the very front. As a matter of fact, I also noticed a large build up of dust, and what looked like burnt dust on the backing panel, which is right next to this large white part.I am wondering if this is the main fuse? PLEASE HELP>>>PLEASE....I really love this t.v., and if I can fix this AND the convergence board, I will be extremely grateful.
  • sendbrianmai Oct 24, 2008
    I have the same problem. Picture is bowed and the channel number is off the screen and all three colors.
  • Anonymous Nov 08, 2008
    yesterday i turned on my tv and the top and bottom are bowed in, and the sides are bowed out. it is model no.p52960, had no problems till today, would appreciate any help you can give me.
  • boodahful Nov 26, 2008
    hey guys my dad is having the same problem with his tv. how do i fix this for him? i basically need a break down in dummy words. like what does solder mean. sorry guys tvs are not my thing but i would love to fix this for him. its almost like the picture is too big for the screen so when you go to the main tv guide you cant even see the channel numer that the show is on. please help thanks
  • snowball0324 Dec 17, 2008
    the picture has a bow at the top and bottom how do i get rid of it please call me at 734 895 7871 thanks pat
  • randcross Dec 27, 2008
    Same problem here, can someone send me the info to make the repair myself. Thanx
  • Pat Morrison Jan 03, 2009
    I have the problem with a 2003 model and I need the IC/STK numbers since I don't have the tech data.
    This is RCA model P52960, Chas. PTK195Y06B
    trusaxman@yahoo.com
  • 4,234 Answers
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Posted on Oct 06, 2008
Lines are bowed at top and bottom,picture is blurry
Is the convergence option still listed under the on screen menu setup options, or has it disappeared?
Jan 22, 2010 | RCA R52WH76 Television
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Bowed picture
you have pincushion problems and may convergence may require a setup/call for service.
Aug 12, 2007 | Philips 43PP9202 43" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
256 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
