Print rubs off paper on toshiba 4550 copier - Office Equipment & Supplies
The teflon coating on the fuser heat roller has worn off and you need to replace the upper fuser roller.
Posted on Oct 06, 2008
After paper is printed in konica minolta bizhub 164 printing gets rubbed out what is the remedy plese
Because the fuser is not fusing the toner to the paper replace the fuser unit the hot part
Nov 21, 2016 | Konica Minolta Office Equipment & Supplies
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
Canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
Reboot turned machine off then on again then came up with CE40
The toner is not getting treated or hot by the drum, if its under warranty call Tech Support if not then you will likely have to replace the drum.
Mar 31, 2014 | Toshiba E-studio 281c Copier
I have a Brother MFC-6490. The printer can not print in black. The black cartridge is new. There is no problem with color printing. Thanks for your help.
Hi
Remove the black ink cartrige and rub the print head into a plain paper with rubbing alcohol until ink flows. If not rubbing alcohol, no problem. Just rub the printhead into a plain paper.
Then try to print again. I hope it helps you. Please post comments if you need more help. Regards
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
My black ink is not working please tell me how to clean it
Hi
To clean it, remove the ink cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. Then run the print nozzle for 2 time for further cleaning the print head. Then try to print again.
Another way is to soak the print head only into a how water for 5 minutes until ink loose up and ink flows, rub the print head into a plain paper with rubbing alcohol until ink flows. Run the print nozzle and then try to print again
Post comment for more help
Mar 18, 2011 | Office Equipment & Supplies
Just replaced black cartridge and it's still not printing
Hi
I suggest to remove the cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. The print the print nozzle for 2 times. Then try to print again.
If not, dip it into a hot water for 5 minutes and then rub it again in a paper with rubbing alochol.
Run the print cleaning maintenance like print nozzle and then try to print again.
If not, you need to go to printing preferences and check the box GRAYSCALE in the print quality.
Please let me know if you need more help.
Mar 06, 2011 | Epson Stylus CX9400 Photo Printer
Fuser drive gear for toshiba bd-4550
Part number is 4402-079300 GEAR-50-H/R Hope this helps.
Aug 27, 2009 | Toshiba Office Equipment & Supplies
BJC 4550
chech if the ink cartrades are plugged in tight in they are check if all the chords are plugged in if that doesnt work go to a tech man or get a new printer
Jul 08, 2007 | Canon BubbleJet i550 InkJet Printer
170 people viewed this question
k24674
