Question about ViewSonic VE710s  (Black, Metallic Silver) 17 in. Flat Panel LCD Monitor
About a problem in my viewsonic monitor
I have a viewsonic ve710s 17 in,my monitor suddenly started flashing (1 sec image-5 sec black ), i tested the monitor by connecting it to another pc and the flashing was the same! what could be the problem? do you think the mon itor broke down?what do you suggest me to do?
  • Scorpiosez Dec 02, 2008
    I have 2 of these same model Viewsonic LCD monitors that exhibit the same behaviour. One of them would do this for about 5 minutes and then (eventually !) stay running. The other one had been set aside because of this issue, and I don't have any other info from the users.
    My suspicion is that is a failing power supply or transformer/regulator. These monitors have full mains power direct to the monitor, so there must be some voltage regulation or step-down for their operation.
    I am looking for a service technician to look at these and see if they are viable to be repaired. I'll report back when I know more.
  • Anonymous Dec 29, 2008
    I have the exact same problem for the same model. isnt there any like easy way to fix it without ripping it apart or anything.
    Problem Solver:
  • 9 Answers
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Posted on Aug 28, 2009
  • Marvin Marcelo Aug 29, 2009
    If the LCD automatic off after few seconds, voltage test the secondary of power supply for normal output.Check inverter area
    the two FET IC N and P Channel, the two IC's were used to drive each high voltage transformer. Check these for shorted Pico fuse or turned high ohm, shorted or leaky push pull transistor, ballast capacitor, burnt pins or loose connections in the backlights connector, check inverter IC use this site for searching part number.
    www.alldatasheet.com. Lastly suspect the mainboard.
My Viewsonic VE710s monitor displays for about 1 second then goes black. Any ideas on what is wrong?
Have you checked the cabling to the monitor? Are you power cycling it to get the monitor to display black?
Mar 10, 2011 | Computers & Internet
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Flicking on and off
If the LCD screen flicks on and off and you can see a dim image on the screen when you view at a sharp angle, then most likely you have a faulty inverter or a faulty CCFL lamp.
Check out LCD Parts for service, parts, DIY info. Use this Link :-
www.lcdparts.net
Sep 11, 2009 | ViewSonic VE710S (Silver) (Black, Silver)...
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at http://www.viewsonic.com/assets/027/7929.pdf
Mar 02, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic monitor VS10780
i turn on after 30 sec turn off that happen all the time
Feb 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic 10049 Keep on Flashing
check no pins on the monitor lead are bent or snapped off
Jan 22, 2009 | ViewSonic VX724 17" LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
ViewSonic VE710s  (Black, Metallic Silver) 17 in. Flat Panel LCD Monitor Logo
240 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
