Question about Kenmore Washing Machines
Kenmore washer My washer will only do the first cycle it won't drain or do anything else. Do you think it is the pump.
  • kderrick Oct 07, 2008
    How do I change the switch lid on a Kenmore washer model # 22622 serial 5043779. Thanks in advance.
    Karen
  • 943 Answers
HI thanks for the question. it sounds like the problem is with the lid switch . i would replace the lid switch. thanks the appliance doc
Posted on Oct 06, 2008
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
Jun 27, 2012 | Kenmore Front Load Washer
Washer won't drain
ND means No Drain(ing). First check that the drain hose isn't kinked. Then, check to make sure the drain hose isn't pushed so far down into the standpipe that it is sealed closed. If it is too tight in the standpipe, it will create a siphoning effect. It has to sit freely but securely in the pipe.
May 30, 2012 | Samsung WF337AA Front Load Washer
Kenmore washer model 8537143 doesn't drain during
have you checked to see if anything has gotten caught in the pump?
Oct 15, 2009 | Kenmore Washing Machines
My kenmore washer will fill up and start the wash cycle but that is it. It will not do anything else, drain or spin or rinse.
I think your pump may be blocked especially if you washed rugs or blankets recently. Check the pump. Hope that helps.
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
