Question about Ovens
Moffat 3000 oven
Need to replace broken door latch
  • Ovens Master
  • 3,740 Answers
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Posted on May 01, 2010
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
I am getting a E1 F5 error on the oven - what is the cause?
E1 F5 error is indicate that door latch is not working
This may display if the door is not shut properly, if it is jammed or if the spring-loaded mechanism has broken. Make sure door is completely closed and switch is closed. Test latch, solenoid and actuation switch (require an ohm meter to test).
Considerations: Try opening the oven door and shutting it while putting pressure on the center of the switch until you hear a click. Jiggle the latch to try and reposition it so that it shuts properly. Examine the latch to make sure it is properly attached.
Prevention/Solution: If none of those methods remove the error, you may need to replace the door latch. Visit the Whirlpool customer service website to find the correct part you need.
Hope this helps.
Jun 02, 2011 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Latch to lock oven door is broken and oven therefore can't be cleaned
need model # to tell you about parts but if latch is broken you will have to replace it . as the p c contrroler will not let you use oven when its not safe .. all ovens lock after 450 to 500 deg / so if you had run a way tempt / or if it went into self clean when it shouldn't it could cause a fire . . so fix that latch mm
Dec 24, 2009 | Ovens
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
394 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
