Question about Lexmark Wheelwriter 1000 Typewriter
Lights blink and machine beeps
Out IMB Wheelwriter 1000 typewriter suddenly started beeping with the carriage moving back and fourth, and the lights blinking. Then it would suddently stop. 5 or 10 minutes later, it would do the same thing. This has been continuing now for 2 weeks. Is there a simple fix for this? We are most likely not going to replace it, but it does get used once a week to type on a blank form that otherwise isn't available on line.
Thank you.
  • Lexmark Master
  • 3,594 Answers
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Posted on Oct 07, 2008
IBM Wheelwriter 1000 Lexmark - Machine beeps and Lights 1,2 & 3 blink. Replaced batteries and still doesn't work.
This is an error code that the carriage or printwheel can't find it's home position. About the only thing you can try is to replace the printwheel or inspect it for bent or boken spokes. If that does not fix it then you will need a tech to troubleshoot problem.
Aug 19, 2013 | Lexmark Wheelwriter 1000 Typewriter
When we turn on the typewriter it will do several beeps and the following line spacing lights are blinking: 1; 2 & 3. The cartridge won't move. Your help is very much appreciated!
Flashing 1,2,3 is a selection homing error. It could be a problem with the printwheel ( bent spokes), the rails the carriage ride on could need lubrication or it could be a bad power supply unit. We have been replacing a lot of power supplies on these units due to the age of the machine. You will likely need a tech to figure out the exact cause. Good luck.
Aug 27, 2012 | Lexmark Wheelwriter 1000 Typewriter
Carriage wont respond
Perhaps the L. Mar. is set there. Turn it on wait for the por sequence to complete, touch the mar rel key, back space to the far left, press L. mar key. If that dosen't do it tou must have some lights flashing and/or beeping, What lights and how many beeps?
DickyO
Feb 26, 2010 | Lexmark Wheelwriter 10 Series II...
Typewriter only beeps and lights blink. Nothing else.
the beeping and the lights are error codes, meaning the machine will need repair
Feb 25, 2009 | Lexmark Wheelwriter 30 Series II...
IMB WHEELWRITER 5
Will the carrier move yo the rt. with power off ? Try a little WD40 on the silver shaft that runs thru the carrier. Look for foreign objects and debris inside the t/w.
DickyO
Aug 25, 2008 | IBM Wheelwriter 30 Typewriter
Beeps 6 times, lights blink
The prinwheel sensor is likely the issue.  Move the carrier to the right, on the left side of th carrier toward the rear of the machine there should be a small black "flag" sticking out of the carrier.  this should move freely in and out if it is not there or does not move the machine cannot detect the printwheel the sensor will need to be replaced.
  You ca also check for debri down in the area where the printwheel sits.
Sep 11, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
133 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
