I have a verine fire which is remote controlled and im experiencing problems charging the battery which controls the fire unit?
  • 2380paul Dec 15, 2008
    The charger does not seem to be working as the amber light comes on for a couple of seconds then goes off
  • naberesford Apr 14, 2009
    have no charger, but would like to know what voltage is the battery for the vertex fire
Check out they can sort out this problem by replacing the batteries inside the battery pack.
Posted on Nov 27, 2008
Where is the infrared receptor card in this equipment to change it. I have a split ac panasonic CS C24BKP and does not respond to remote control. I know the remote control is good because I saw thr...
There is a receptor on the below the front pannel but the problem could be :
1.Low battery charge in the remote control.
2.The signal cable that connects the receptor to the card(pc board) could be loose/disconnected
3.Try one receptor from a working unit
4.Try a remote control from a working unit
May 02, 2014 | Heating & Cooling
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Manta quadcopter won't recognize the remote
Turn on the remote controller first then heli the instructions are wrong
Dec 24, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Won't charge in cradle, shows slide show then goes dark. has power to remote won't charge know matter long it sit on it
The early 880's had problems with the charging circuit. For a while Harmony was replacing these units even outside the waranty period. Not sure if they are doing this anymore. However your remote is recognizing that it is in the craddle because the slide show starts which means the charging circuit in the remote is not passing power onto the battery or the battery is not making a good connection inside the remote. I would pull the battery and clean the little contacts in the remote and the contact pads on the battery. If you have a volt meter I would pull the battery and check voltage. You should see around 4 VDC on the 2 outside copper pads if it is charged. If it is charged and the remote is not working then its time for a new remote. If the battery is dead then it is likley the typical charging problem of the 880 is causing the failure. Hopefully cleaning the contacts both inside the remote and in the charging craddle will solve the problem. Use alcohol and a q-tip to clean all of the contacts.
Good Luck
Apr 01, 2010 | Logitech Harmony 880 LCD Remote Control
Unit "froze" Is there a reset?
I had a similar problem with a MX-3000 2 years ago. The unit would continually freeze. I think it was a problem with the first few units. Since then I've bought a new one and had no problems. Then this weekend, it froze for the first time (the battery is not holding a charge so I think that led to the problem).
If you open the back cover, there is a silver button just above where the battery plugs into the remote. Pushing that button should perform a reset. As an alternative, you can remove the battery at the connector. It is recommended that you use the button and not the connector. It is in there tight on my unit and pulling on the wires can cause a break.
Dec 16, 2008 | Universal Remote Control MX-3000 LCD...
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Remote control problems
Replace your battery in the remote. Dont leave something sitting on the remote that is pressing a button down, or it will drain your battery
Jul 06, 2008 | Jensen VM9020TS Car DVD Player
Televison & Video Logo
390 people viewed this question
Top Televison & Video Experts
