Question about Watches
I have a ridgeway by kelty Cottonwood Model # 890140 tent. I am looking for replacement part Fiberglass tent pole Part # 97-0012
I have a Ridgeway Grandfather clock ser # 95016098 what is the age and approximate value
from what i can tell, it's a model that is no longer made but was produced from 1984-1991 and depending on production number (the last four of the serial, the first four being the model) they are selling online anywhere between $500-$3000 i would contact http://www.ridgewayclocks.com/ and see if they can give you more detailed information. hope this helps
May 09, 2016 | Watches
Where can I get an owners manual for field and stream tent, model 36002
Field and Stream may be able to supply a manual.
Oct 05, 2014 | Watches
Citizen QA4360 Sporty watch after battery replacement dont alarm. What is the problem wit it?
If the watch now makes no sound at all, no beeps ever, It seems like the alarm unit noise generator, has been disturbed when you opened it. Ignore the battery and look for the sound transducer behind the holes in the case where the sound comes out. Is it dirty or have any wires to it broken?
Dec 20, 2013 | Watches
Folding instructions
You may have to fold it tightly, then squeeze out trapped air before it will fit
Jun 14, 2013 | Eddie Bauer First Ascent Stargazer 3 Tent,...
How much daylight does the north pole receive each day?
It depends upon the season
Check out this WEB site for more info.
http://www.arctic.noaa.gov/gallery_np_seasons.html
Mar 11, 2013 | Watches
I have a traileader 2 watch and the light has stopped functioning. I have replaced the battery but that hasn't solved the problem.
Hi gicarroll, I am Martina. I work on the customer service & technical support team for Tech 4O, Silva & Eureka! tents. I am sorry to hear that the light on your Traileader 2 Watch stopped functioning. I would love to help resolve this problem. Can you contact me directly at 800.572.8822? If email is easier: camping@johnsonoutdoors.com? I look forward to hearing from you.
Feb 09, 2011 | Silva Tech4o Northstar CW3 Compass Watch
What is the prime meridian of the earth
It is defined as the position( imaginary line) on the earth that runs from the north pole to the south pole and the longitude is zero degrees. The international date line is on the opposite side (180 degrees)
Dec 25, 2010 | Watches
If polar bears are starving in the north pole why arent they taken to the south pole
'coz in south pole they will be hanging heads down and falling off the planet.
Aug 04, 2010 | Polar F6 Wrist Watch
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
156 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
