Question about Compaq Presario 5000 PC Desktop
Problem with shutdown
End programe is not working properly
  • Jeff Strader
    Jeff Strader May 11, 2010
    Pleae tell what program and a little more detail about the system and what exactly it is doing when you try to close it.
  • 749 Answers
Also go to START- ALL PROGRAMS- STARTUP.. These are startup shortcuts for programs that add default startups for programs installed since windows was installed. right click on any programs here and press delete to stop thier starting. This will not uninstall or change anything besides keeping there programs from starting when windows starts. All can be opened manually after the comuter boots still.
Posted on Oct 07, 2008
  • 558 Answers
Is there any error or the System hang out during Shutdown!
You can do one thing disable the startup items from the msconfig.
Go to start -->Run-->Type msconfig --> open the startup tab -->uncheck or disable all items listed here.
If you face any difficulty add more details, so we can further investigate the problem.
Posted on Oct 06, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
I have a problem with my pc when I shutdown it down. it comes with force shutdown. it never had m before. how can I fix this problem. if it is a problem
This usually means that there is a program open that is unable to close itself properly, or maybe you have a document that has not been saved, so there is a dialog box asking if you want to save it, but you cannot see if it since you are on the shutdown screen. When it asks if you want to force shutdown, you should see a list of which programs are still shutting down, check on those.
Sep 07, 2017 | Computers & Internet
Auto End Tasks to Enable a Proper Shutdown
This reg file automatically ends tasks and timeouts that prevent programs from shutting down and clears the Paging File on Exit.
* Copy the following (everything in the box into notepad).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
[HKEY_USERS\.DEFAULT\Control Panel\Desktop]
* Save the file as shutdown.reg
* Double click the file to import into your registry.
NOTE: If your anti-virus software warns you of a "malicious" script, this is normal if you have "Script Safe" or similar technology enabled.
on Dec 23, 2009 | Computers & Internet
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
Satellite A300 shutdown unexpectedly
One bad lead can cause a computer to continue restarting on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
Jun 20, 2012 | Toshiba Satellite Computers & Internet
My computer is on but no picture. It says windows was not shut down properly
Hello Pattiaknight,Make a desktop shortcut to shutdown and include a switch that forces all open apps to shut down without warning.
Just right click the desktop, New, Shortcut, type:
Shutdown -f
Shutdown -f closes any open programs without warning.
Now instead of shutting down the usual way, just use that shortcut to shutdown. If the error stops it means some program wasnt shutting down properly on occasion.
Please let me know if you any further questions or concerns.Also please rate it if you like the answer,it helps alot.
Apr 19, 2012 | Sony Computers & Internet
I have a Acer 5517 64bit windows 7 laptop. Just recently I updated my memory cards from two gig to four gig. Now the laptop will not shut down properly. I replaced the old memory cards, and it's still...
Try UPDATING the BIOS firmware first by going on the Acer web site, go to support than download than enter the laptop model...
Download the corresponding BIOS firmware (if they have an .ISO file) than burn it to a CD using NERO so that the CD is BOOTABLE, than BOOT with the CD and fallow the instructions
Hope this helped!
Feb 20, 2011 | Acer Aspire One PC Notebook
I am using XP.. net modem working case if take a long time for System shutdown.. if put off modem immiditly shutdown. how to shutdown if working modem.
Windows Server tries to "gracefully" shutdown.
This implies that any "active" network-connections that use the modem will be signalled to "properly" close. This may take a while, waiting for the "other" end of the connection to respond.
However, if you have no active network-connection, then Windows does not need to "wait" for the "other" end of the connection to respond -- it can immediately close the "severed" connection.
Sep 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Will not shut down. gets to logging off screen and freezes
System unable to shutdown or take a long time to shutdown may be due to windows services not responding properly when the termination command is executed by the Operating System..
System restore usually doesn't help in this kind of situation so uninstall any program that you don't need.and Remove all the programs that loads when the system startup.
You can uninstalled program in the Control panel using Add/Remove Program tools which is very simple.
To remove startup Program,
Click "Start" Buton,
Select "Run"
Type "msconfig"
Click "startup" tab
untick all the programs and reboot the system.
Hope this will fix your problem.
But there's also another instant fix,
Download this software called "Super Fast Shutdown"
Here is the link
Jan 01, 2010 | ASUS Eee PC 900 PC Notebook
Windows XP-Home Edition Shutdown problem
The MCCItrayapp is a manufactures application,
try this-
ctrl+alt+delete -> shutdown(in the menu) -> ctrl+shutdown(in menu)
This will shutdown your computer in 5 sec.
Jan 10, 2009 | Microsoft Windows XP Home Edition
When i turn off my computer it says END PROGRAM ccSvc.Hst When I press end program it takes forever for my computer to turn off. Also other option says press cancel and return to windows when I do this...
That file is part of Norton/Symantec security suite. I've seen that error on many systems with Norton Products.
You may be able to avoid the error by closing Norton in the system tray prior to shutdown of the system.
When you select shutdown from the menu, windows forces all running programs to shutdown, including the antivirus. For whatever reason, sometimes Norton doesn't like the shutdown request.
If you are not especially attached to the Norton product, you might try uninstalling it and trying AVG or Avast antivirus. is the link to download AVG 8.0
May 14, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
