Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Frige w/out during elec strom..light comes on..frigdge not cooling now
Someone told me it may be the 'timer'...I can't find the timer...I can hear the sound of refrigerator but it's not cooling...and the light comes on inside.
Help, my Amana refrigerator is about 7 years old...and I really like it.
Not sure of model #...Brenda
Contacted appliance repairman
Posted on Oct 07, 2008
Frezer working fine but frige.side cooling not pass 42deg.
I would think it is a defrost problem that is the first symptoms on most refrigerator. Look inside the freezer is ice building onone of the walls like this PHOTO? Can you locate the model number around the fresh food section door? With the model number I can see if there is a defrost timer, ADC or motherboard controlling defrost. Thanks for a model number. If I cannot help someone will with a model number to go by, Thanks Sea Breeze12_17_2012_3_59_13_pm.jpg
Dec 17, 2012 | Refrigerators
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Frige conparment is not working but the light still comes and the frezer is in good woorking order
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Mar 31, 2011 | Smeg FAB40PS Top Freezer Refrigerator
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
Light on no fan
it sounds as though the thermostat is faulty not bringing the compressor on and the defrost timer is turning the fan off and on as it should do
May 02, 2009 | GALAXY Microsystems 63702 Top Freezer...
Fridge is not cooling on my Maytag MSD2756GES
Check thermostat and fan switch. If not same thing need changeagain
Sep 04, 2017 | Master Bilt Indoor Step In Cooler 70""W x...
A/C turns on and cools but Heating system does not turn on when switched fron a/c to heat. All I hear is a click form the heating system.
Depending on whether you have a gas or elec. heating system it could be a fan control module or a heat sequencer. It's not the thermostat since it is clicking calling for heat. It's not the blower motor because it comes on during cooling. Either way it's an inexpensive repair.
Oct 13, 2008 | Amana Heating & Cooling
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
75 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
