Question about Whirlpool Refrigerators
How to troubleshoot a start relay for w-pool ref part # 2212964
  • Anonymous Nov 09, 2008
    Refrigerator will not cool and a loud Click is heard periodically.
  • Anonymous Nov 21, 2008
    Mom's Whirlpool refridge is only 6 years old. It had been making a weird noise for a couple years. It sounded like the compressor was trying to come on and it would 'click' or 'clunk' loudly several times before the compressor would stay on. Sometimes it would cycle on and off for several minutes before coming on and staying on. Now it fails to come on at all. I checked out everything on the fridge I could (thermostat, defrost circuit, etc) I found that the wiring diagram was neatly folded and hidden in the control compartment. I narrowed it down to either the compressor or the start/overload relay but don't know how to check this relay 3ARR55M4F1A. I can find a replacement part but would like to know whether or not this part I have is faulty before shelling out money. How do I check it?
I had exactly the same problem with my 6.5 years old refrigirator. Finally, yesterday it died. All the fans were running, but the compressor was dead. I called an appliance service, the guy came to my house an hour later and replaced the relay in about 10 minutes. Charged me $170 for everything. After he left I called couple of places for the price on the relay, no one had it in stock, they could get it in 7-10 days. The relay was $42.99. Now I feel kind of stupid for spending that much money, but I couldn't wait that long anyway.
Posted on Dec 01, 2008
AQUA LOGIC WILL NOT START UP OR COME ON WHEN FILTER BUTTON IS PUSHED
if filter pump breaker is on if 220 volt make sure both are on if thats ok you need to check the wiring going to the relay if ok you have a bad relay you need anew filter pump relay for the control box they go out ocassionally
Jun 11, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
Low ref pressure
check filteres if clean check pressure switch voltage both sides should be 24 volts
May 18, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
I installed a new defrost timer and the compressor clicks but it will not come on. i have a kenmore ref 1069535780
The compressor clicking, this is related to faulty start up relay/ capacitor of compressor.this relay lets the compressor to start.if this relay is weak or faulty, then it will just click, but not let the compressor to start.This relay needs to be checked and replaced.--------- Click the link below for more help:-- http://technoanswers.blogspot.com/2011/06/refrigerator-compressor-clicks-but-it.html ------------ This will help.Thanks.Helpmech.
Jun 02, 2011 | Refrigerators
Wont start.no fuel at fuel rail.has new pump
Pull the fuel pump relay in the engine compartment fuse panel and jumper the normally open contacts ( red line in the picture below )
If this works, you can use the trailer tow adapter battery charge relay as a replacement until you get a new relay. Most auto stores can cross ref the relay.
My 2001 at ~ 35K miles had a bad fuel pump relay, causing a crank no start issue.
Mar 07, 2011 | 2000 Ford F150 Flareside SuperCab
Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Pool heater wont start but when i turn off the pump and start back again the pool heater comes on for 2 seconds and shuts off AGAIN
Heater must have water before it will fire up. There is a delay relay that may be dozing off. Not a bad thing but should be chk'd by a pool sevice.
May 26, 2009 | Heating & Cooling
The compressor runs and then would not re start when hot.
unlpug the ref. Then plugged on to the side of compressor is a relay if you can remove the relay shake it if it rattles like something is broken then you have a bad relay if not you have a bad compressor good luck let me know if you have any questions
Mar 31, 2009 | Refrigerators
Compressor not running
Try replacing the relay.
I would get a universal relay, if it doesn't start keep the relay for your new Ref. if needed.
Nov 03, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
480 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
