My laptop is used for presentations with a projector. For some reason the last time I used it the projector would not pick up the information from my laptop We tried unplugging starting again, checking all the plugs etc. I tried another laptop and it worked fine. Thank you
  • Anonymous Mar 28, 2009
    All of a sudden my laptop does not pick up my projector? My operating system is Vista Home Premium.
    Is this a Vista problem?????/
  • 34 Answers
Sometimes you have to hold down the function key (usually labeled FN) and then press one of the F keys to get the laptop to send the signal to the projector. On my laptop its FN + F8. The key should have a picture of a monitor or say something like CRT/LCD.
Posted on Oct 07, 2008
I cannot seem to link up my projector and laptop computer
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Mar 09, 2011 | Vivitek D825MS Projector
Cannot find the source
Try lowering your laptop's screen resolution and refresh rates to the lowest possible.
Additionally, you need to press Fn + F? keys on the laptop to cycle on laptop display, laptop display + external; display, external display.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Optoma HD70 DLP Projector
I need to be able to connect my hp pavillion to a projector to display a power point presentation. What is the correct process?
Usually all one has to do is power up the projector, then while the laptop is turned off, plug the projector into the VGA port, boot the laptop, and there it is.
If that doesn't happen for some reason, you'll have to go into display settings and make the projector the primary display.
Nov 29, 2010 | HP Pavilion dv6000z Notebook
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Step 3
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Step 4
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Step 5
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
Projector does not work with computer
Hi Connecting a laptop computer to an overhead projector is a relatively simple process. That said, it can be a disaster to work hard on a presentation, be it for a school or workplace environment, only to show up and find yourself unprepared. Take the time now to learn about the different ways your laptopmag-glass_10x10.gif can connect to an overhead projector, and how to accomplish this easy task, and you can enter your presentation with poise and confidence.
Jul 31, 2010 | Eiki LC-XE10 Projector Multimedia...
I have one projector and two laptops can i use this device in the middle, i want to use both Computers for presentation one by one
You can plug them both up to the projector and switch inputs on the projector probably. I also see no reason why the KVM switch shouldn't work.
Jul 20, 2010 | D-Link DKVM-2K 2-port KVM Switch
Cannot see videos when connecting my HP laptop to Panasonic proje
this is mostly due to the laptop screen resolution please change the resolution by the below step by step procedure.
right click desktop -> properties -> settings->screen resolution.
did this information help?
Mar 27, 2009 | Dell Inspiron E1705 Notebook
Laptop is not being connected
THE PIN CONNECTION MAYBE DIFFERENT IN THE OTHER LABTOPS YOU WOULD HAVE CONTACT THE VENDEER AND CHECK THE PIN OUT FOR THAT PORT AND SEE IF THEY ARE THE SAME.
THE COMPUTER CABLE SPACIST CAN HELP YOU, CABLE CONNECTION, CABLE AMERICA, AND CABLES TO GO.
ROD
Feb 17, 2009 | Sanyo PLC-XU73 Multimedia Projector
Hi. Love my projector. For some reason tonight, it wouldn't sync with my laptop for an important presentation. The cable works, because we used my cable (pin connector) to hook up the other projector....
Have you toggled the output display function key on your laptop. Should look like a Square Screen and Laptop symbol. Plug in the projector and keep pressing this button.
Jan 22, 2009 | Computers & Internet
Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
Dec 15, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
David Payne
David Payne
