Question about D-Link AirPlus DI-524 Wireless Router
My laptop did not detect the D-link driver
I connected the ethernet adapter to my laptop computer to configure it,the problem is, i cant seem to find the d-link driver in the devicemanager.. is my router, specifically the driver not working? iv triedtroubleshooting on my own but this seems to be the big problem, i cantconncet to the configuration section wherein i typed 192.168.0.1 in thebrowser.. it appeard "the connection timed-out".. im just guessing, mylaptop cant detect the d-link driver thats y i cannot configure it,, ami correct guys? pls help! thanks!
    Problem Solver:
  • 6 Answers
I guess your trying to connect without a cable....
Try to connect to a KNOW good router.
Try connecting with a cable.
Try connecting with another computer to your router.
Let me know what you get.
Posted on Oct 06, 2008
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
My laptop has been switched off for a week. when i turned it back on, it cant find any wireless networks or my wireless router. i can only get online by manually plugging the yellow lead from pc to router....
- It seemed that there is no wireless network driver that is installed on the computer
- I also noticed that you can connect to the internet using a wired connection
- you can download the wireless driver using the computer manufacturer's support website (e.g support.hp.com if it is a hp laptop , support.dell.com if it is a dell laptop)
- if laptop is customer built you can go to start -> run -> msinfo32
- Under system summary-> components -> network you can find an idea what kind of wireless network driver you have
- and you can google and download the wireless network driver
May 16, 2011 | Computers & Internet
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
Bought a G Wireless USB Network Adapter, on install when it asks to plug it in the computer cant find it, then I get a error message that I need to instal the network card
To configure the wireless router, it needs to be connected to a computer with a LAN cable. Therefore the computer needs a LAN card and the LAN card driver installed and if you need to connect a laptop or computer to the router by wireless then the laptop or computer needs a wireless card plus the wireless card driver.
To configure the wireless router and wireless cards in the laptop or computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 06, 2010 | Belkin Computers & Internet
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
Can not detect wireless network on wifi enabled
Make sure on laptop wi fi switch is turn on.
Uninstall wi fi network adapter driver then reinstall.
Right click on my network places and click on property then right click on wi fi adapter and enable it and click on view available wi fi networks .
If you still not detect signal of router then You hav to reset router.
For thjat press RESET button for 10 seconds it is in back panel of router.Then it defaults.
then connect router to computer with ethernet cable then you can access it with below link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Then set WAN settings as your isp.
GO to wireless settings and enable it .
If you want to secure enable WEP security and add wep code.
Enable DHCP.
Then save and restart router then check.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | HP Compaq nx9020 Notebook
Wireless not recognising wireless router
Are you using Windows XP? If so, pls make sure that the Wireless Zero config utility is enabled:
Start>Settings>control panel>administrative tools>services>highlight 'wireless zero configuration utility>click 'start the service'.
Then you will need to go back and open the page for network connections, view available wireless networks, click on advanced, check box 'Use windows to configure my wireless connection', click ok.
After this, do you see any networks in that screen?
Feb 10, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
D-Link Air DWL 520 802.11b Wireless Adapter problem
On the computer with the USB wireless card. Uninstall the wireless adapter program and use only the driver so that you can connect with the Windows wireless configuration utility. Then restart the computer and see if you are able to see the signal now. if not create a profile put in the SSID of your network and connect
Nov 19, 2008 | D-Link Air DWL 520 802.11b (DWL-520)...
Ethernet controller device for ACER Extensa 5220.....help please!!!!
Yellow question is indication of absent correct driver. you can download latest matching driver manufactuers website.
Once you update with correct driver yellow mark will otherwise it will work for any configuration.
Aug 26, 2008 | Computers & Internet
Laptop connection to Internet
In the simplest terms buy a longer ethernet cable or multiple ethernet cables and route them to several preferred areas.
However believing you probably would like to connect wirelessly
If your laptop has a built-in network card and originally came with Vista you may need to configure the network adapter and/or the router appropriately. There are often user guides for the both the adapter and router that will assist.
If your laptop has an built-in wireless adapter and you upgraded to Vista you should check the manufacturers website using support or drivers links to see if they have Vista software/drivers to support your built-in wireless adapter. IF not you may want to consider the purchase of a compatible add-on wireless adapter as noted below. And perform the appropriate configuration(s) as noted above.
Likewise if your laptop does not have a wireless adapter you may wish to consider purchasing an adapter. Care must be taken that the adapter is compatible with your computer, your operating system (Vista) and your wireless router (apparently WBR-1310).
Dec 06, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link AirPlus DI-524 Wireless Router Logo
209 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
