Question about Sony KP-51WS500 51" Rear Projection Television
KP51WS500 It is like looking at 3-D but without the glasses. I looked in the downloaded service Manual but unable to figure out the Convergance IC's mentioned by you. Can you please help me locating the same. Thanks Sharad Aggarwal
  • john008 Oct 11, 2008
    I have the same problem with my Sony TV, but guessing the lamp has reached it useful life.
  • SPEEDRACER35 Oct 25, 2008
  • 2,920 Answers
You need to have the tv re converged
Posted on Nov 04, 2008
Double vision
its convergance ic STK392-150 will cure your ills . check the resistors make sure none are off value.
Jul 08, 2010 | Hitachi 43GX01B 43" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Oct 19, 2009 | Panasonic Televison & Video
I have a PT51HX41C. The convergance is not working, and everything seems like 3D without the glasses. IC chips? How many? Where? Part number? Thanks in advance.
Ur tv nane and model,the convergence IC chips will be in that kit.U know how to solder right?Tries these websites.Tv Repair or
Sep 29, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Hour glass bowing on the top and bottom of my HCP4752W Samsung
Check the resistors near the ic, and the fuses to the ic's, i bet you will find an open fuse. the fuse will look similar to a resistor without color bands. use a dvm and set it on ohms, with the tv turned off.
Sep 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence Issue?
1 read the manual,2 look under convergance,3 follow the instructions.if you can not do 1,2 or
find a hetrosexualman that can read and make him dinner.If you do not have a manual look up the manufacture and you will be able to down load one for free.
Jan 18, 2009 | Mitsubishi WS-55807 TV
Convergance IC 52 Inch Mitsubishi
If its the early mitsubishi they are located on the far left side of the chassis looking in the back they are attached to a large heat sink. If you post the model number of your set I can post the correct ICs that you need as well as where to get replacements that have free instalation instructions with pictures.
May 20, 2008 | Dell GX270 P4 256/40/48X/XPP/NONE...
Looks like watching 3D movie(colors) and rounded
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi vs430ca service manual
are you sure it convergance and not the convergance amp ic?
Dec 05, 2007 | Televison & Video
Bent image
Excelent description,whats happening is your set starts to show a blue convergence problem and is only correctable by replacing the blue convergence amplifier IC,the set has 3,one for each color,not all of them develope problems but they all develope loose conections,after the IC has been replaced there are adjustments to do.If you are familiar with tv service this information will give a place to start but if you are not too familar be safe and call a servicer to help you.Lets US know how it goes.
Oct 13, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
