Question about HP PSC 750xi All-In-One InkJet Printer
How do I access the ink jets?
I have an HP psc 750xi printer. How do I open the access door to change ink jets?
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see and indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the carrage.
Posted on Dec 09, 2008
What precautions or steps need to be taken before,during and after installation of ink cartridges ?
You shouldn't have to do anything.. Most printers will clean the cartridges themselves automatically
May 01, 2015 | HP PSC 750xi All-In-One InkJet Printer
I have a new computer with windows 7 premium 64 bit and a hp psc 750xi all in one printer how do i get the drivers to have my printer work
  1. Navigate to the HP website. http://www.hp.com.au
  2. Click on the Support and Drivers section, located at the top right of the page.
  3. In the for product field - type in: HP PSC 750xi All-in-One Printer. Press <Enter>.
  4. Click the Software and Drivers Download link.
  5. Click the link Microsoft Windows 7 (64 bit).
  6. Click on the link that says, Installing the Product with the USB cable ...
  7. Here you will find HP's solution to the problem.
Note: HP have not updated their drivers for this printer for use with Windows 7. You will be able to get basic functionality from your printer, but not all of the features of your printer. You may wish to shop around for another printer. If you do, make sure you check what systems the printer works on (i.e., xp, vista, windows7) etc...
Regards,
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
How do I know when my HP Printer 750xi is out of ink? I don't have the manual. Thanks, Fixya Guys!
The software will pop up and notify you. If it doesn't you will notice, it will print and be very very light in color.
Don't worry, they last a while ;)
Thanks
Tim
Aug 12, 2009 | HP PSC 750 All-In-One InkJet Printer
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Cant get to the ink cartridges
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see an indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the sliding carriage.
Caution - do not close the printer until you lower the cartridge levers. Why? - The carriage will want to slide to the right (home position) and the levers will stop that. It makes quite the racket and can cause part damage.
Hope that helps!
Nov 29, 2008 | HP PSC 750xi All-In-One InkJet Printer
Clogged inkjet ports on an hp psc 750xi
UNCLOG INKJET PRINTHEAD NOZZLES
Soak the printhead in hot water ! It works !!
_submerge printhead in aprox 0.1 inch water in plate
_hot water from faucet.... heat plate and water in microwave
_do not exceed 160 F or too hot to touch
_soak until ink comes out in water...
....usually a minute is good enough...sometimes 15 min
.....if it works and then goes dry soak some more
ALSO
CHECK THAT THE CARTRIDGE HAS INK by postal scale weight or by feel.
Compare to known full and empty carts....ink is about one ounce
and empty cartridge 2-3 ounces.
RESET REFILLED CARTRIDGES
Google search: reset C6578 and reset c6615 and find
http://www.refill4.com/refillinstructons/hewlett-packard.htm
If this donotwork search and try the other resets.
RESET THE PRINTER'S MEMORY FOR THE USED CART
I am still trying to find an effective way to reset the printer memory..
....'maybe remove the CMOS battery on the pprinter board
if I can figure out how to get at it.
Jul 27, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750xi All-In-One InkJet Printer Logo
44 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
