Pioneer DVD Recorder DVR-420H. HELP PLEASE ! When I record fom hard drive to a DVD, the DVD plays perfectly on my Recorder, but it always is incompatible with any other Recorder. I believe it may be because of the type of DVD disk I am using, which is "Just Record Universal Inkjet 4.7 gb .4X DVD-R" Look forward to hearing from you. Kind regards Malcolm Canning
SOURCE: Unlock Pioneer DVR-531H
check ebay - i got a disc for my 530h on there which unlocked it perfectly
Posted on May 05, 2008
Agent Aaron
  • 265 Answers
SOURCE: DVD recorder with NTSC tuner
Hey Whormd,
If neither your DVD recorder nor your TV has a digital (ATSC) tuner, they will not be able to directly receive over-the-air broadcasts after the DTV conversion is completed without the assistance of a set-top converter box. Please keep in mind that the official analog broadcasting cut-off date does vary by country. In the U.S. this date is February 17th, 2009, and that Canadian TV stations have until August 31st 2011 to make the transition.
Please also note that you will need one converter box for each device with an analog tuner, in order to watch one program while recording another. One converter box would need to be connected to the DVR, while the second converter box would need to be connected to the TV itself.
For more information, I would strongly suggest checking out the FAQ sections of the official DTV websites established by the Federal Communications Commission (FCC) and the Canadian Radio/Television Telecommunications Commission (CRTC):
http://www.dtv.gov/index.html (FCC)
http://www.crtc.gc.ca/ (CRTC)
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 10, 2008
  • 223 Answers
SOURCE: pioneer dvr-420h
Could be a blown internal fuse or a fault on the power supply board. If you can check these things yourself look towards a voltage regulator as the main culprit. Good luck.
Posted on Sep 26, 2008
SOURCE: DVD Recorder Does Not Record
Yes, I agree. Dust on the lense will create this error as it did on mine. However, to save you a lot of tech fees or difficulty in dismantling the machine, just buy a can of AIR or Duster, etc. Open the DVD slide and "unplug" the unit from the wall. This will leave the door open. Lightly push the carrier back about halfway. Use a flashlight to look into the DVD and find the center area. Place the plastic tube on the air can in this area and blow it clean. Don't scrape or touch any of the mechanisms inside for safety. Plug it in and it should work if it is dust. This of course does mean that it will likely do it again and could use a 'good' cleaning as suggested above. But it is an easy quick fix. And if you are like me, I won't use it again for another six months.
Posted on Oct 01, 2008
SOURCE: Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
I want to record a film off my camcorder directly on to the hard drive of my Panasonic DVR-645H-S DVD recorder. I have put the input plugs at the front of the recorder from the camera but cannot get a...
You have to select the correct External Input, on TV, you do NOT use "Channels" Then select correct format either NTSC or PAL, turn on camera to play, then you should be OK.
Mar 07, 2010 | Pioneer DVR-645H-S DVD/HDD Recorder
Pioneer dvd recorder/player does not read its own recorded dvds, and some others recorded on other players it throws them out?
Thanks for your help re: dvd player recorder.
I have now desided it needs a new read write drive and am searching for local repair shop to do this.
Thanks again
Vasos574
Oct 18, 2009 | Pioneer DVR-5100H DVD Recorder
Pioneer DVR-5100H : CPRM error after changing DVD drive
I've never fiddled with this dvr but i belive there is a service cd you can download if you search around. Not sure it will help but i guess it's a start.
Apr 11, 2009 | Pioneer DVR-5100H DVD Recorder
Pioneer dvr-420h
Sep 20, 2008 | Panasonic DMR-E55 DVD Recorder
I have just purchased a pioneer dvr-lx60d dvd recorder with a 250 gig hard drive built in . i would like to know how to back up my dvd collection on to the hard drive .?? can you help. the player wont let...
i have played a dvd movie in my laptop computer(Toshiba dvd player) it has played
but when i try to ply it in my desktop computer(LG dvd player) the disk is not opening do you have a soft ware or suggestion to solve this problem
Jul 13, 2008 | Pioneer Televison & Video
Mar 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
My dvd player will not play HD-DVDs it is an HD DVD player
This dvd player doesnt' play HD DVD's it has a HDD which is short for Hard Drive. Which means you can use it like a DVR (Digital Video Recorder) to record your favorite shows and things like that.
Does this answer your question? If not i'm not sure what you're trying to ask could you be a little more elaborate?
Jan 25, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
Dvd recorder wont finalize etc
The DVD drive works harder when trying to record the info faster. As the unit ages, tracking is less precise. DVD-R copies occur at 4-16X real time. Try DVD-RW disks which copy slower (now that the price has dropped substantially), and you may find that your aging drive can still copy programs from the HD to the DVD.
Oct 16, 2006 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
