Question about Adobe Photoshop 7.0 for PC
Maintaining original picture size after cropping
I am projecting digital pictures through a Optima HD70. I am trying to achieve consistency of projected size af all pictures on the screen. How do I avoid the variation in size caused by cropping in photoshop. What I want to do is crop pictures but maintain the original picture dimensions. I know this would change the resolution but if the shot comes from a high quality SLR Canon 400, it should not loose too much quality. I do not fully understand the relationship between the size of picture displayed in the edit screen and the the final size of a saved image.
David Judd
  • Hamhog Oct 07, 2008
    Hi Maruthiairco, could you give me more detal as to what you are saying please, many thanks.
Pls instll photoshop
Posted on Oct 07, 2008
PS CS6 How to drag a layer into another PSD file at-size?
>Open "My Computer" from your desktop. Double-click your hard drive.
>Open "Documents and Settings."
>Open the folder labeled with your user name.
>Open "Local Settings" followed by "Temp."
>Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
>Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
>Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent.
also use Photoshop Restore Toolbox
Apr 25, 2015 | Adobe Photoshop 7.0 for PC
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
How to enlarge/reduce photo size & maintain proportions
I think you are referring to "crop".
After pasting the picture in MS Word,
You would see "Picture Tools" top tab. Then under "Fomat" you would see "crop" click on it and try editing your picture.
It should reduce the size of your picture and maintain the normal image size.
Hope this helps.
Jul 17, 2011 | Microsoft Office Word 2007 Full Version...
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
How to make file size of photos small to send by email?
I'll give you a trick! it has a large file size because of pixels, so you need to minimize it.
Open the file with mspaint and crop"
1. right click the file that you want to minimize file size, then choose " open with " then there's a option of program, choose the mspaint .
2. then once the picture was already open with mspaint, goto toolbox and choose the Crop tool..
3. Crop the picture..then open a new mspaint, then paste the cropped picture into it, then save afterwards..
4. then its done.
Good luck & please rate..
Mar 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I just bought a fujifilm A170 and a canon printer for my work. The editing program is finepix. The problem that I am having is..........I tried to zoom in on the picture to bring up more of the detail...
I think your printer is seeing the original picture still using your method.
Try cropping the area of the picture that you require, zoom in to your required level then saving it with a new file name.
Print the new file. It should the cropped portion of the original picture.
Mar 29, 2010 | Fuji FinePix S5000 Digital Camera
Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Pictures are to big
You can use Microsoft Paint to reduce the physical size/crop your picture, or you can use a program called Winsoftmagic to reduce the physical size of JPEG pictures without cropping.
Mar 26, 2009 | Sony DSC-T70 Digital Camera
Help me
Most digital SLR cameras take pictures with an aspect ratio of 2 to 3. (This is based on the size of 35 mm film, where the images were 24 x 36 mm, a 2 to 3 ratio.) That is a different ratio than 8 x 10 inches, which is 4 to 5. There is no way to change the aspect ratio in the camera, so you will have to make sure when you're taking pictures that will be printed on 8 x 10 paper, you leave the processor extra area to crop the portion that won't fit in the 8 x 10 frame.
For information, the 8 x 10 picture became popular when many portrait photographers used 4 x 5 large format film cameras, which obviously will fit perfectly in an 8 x 10 frame without cropping.
Mar 22, 2008 | Canon EOS-20D Digital Camera
Panasonic PT-47WX53 Horizontal Picture Size
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable or satelite receiver box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 28, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Adobe Photoshop 7.0 for PC Logo
96 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
