Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Connecting Lyd Model#203 mini-cam to Sony DCR-HC28 Handycam
The Lyd mini-cam will supposedly work with a Sony DCR-HC32 as seen on this demonstration video http://www.instructables.com/id/Covert-Spy-Sunglasses/
I have the same color/audio mini-cam NTSC CMOS. When I connect it to my
DCR-HC28 utilizing the Sony a/v cable the mini-cam doesn't work. I know the
Lyd mini-cam is working because I checked it on a television.
The a/v cable on the HC32 in the demo is 2-plug where mine is 3 (video, left audio, right audio). Do I need to utilize certain settings on the handycam.
Thanks for any suggestions.
The HC28 has a/v out only - whereas the HC32 has a/v in/out capability of which only certain models of camcorders have.
Posted on Oct 14, 2008
  • lafiebredelt
    lafiebredelt Aug 01, 2012
    i need the driver or software to this cameras. sombody can help me
On a Sony Handycam DCR-HC28 there are grey lines running horizotally during play back mode. Both on the camera touch screen and on our TV when we play it back.
Cleaned my heads and internals with alcohol and q-tip and blew it out with compressed air( LIGHT PRESSURE) approx 30 lbs press. works great.
Jan 15, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
Problem with the Sony Handycam DCR-HC32 Mini DV Digital Camcorder Moisture condensation turn off 1 hour
It can be a tiny dew switch mounted on near the drum motor, Which you can change off values with a resisitor for the fault .
Also if you can blow hot air into the cassette tray this would enable the dew switch to open out.
Sep 28, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
SONY HC32 - LCD panel not working when pressing icons. Also, when it does work, the incorrect functions appear for the menu selected
I had similar trouble on my 2nd hand HC32 - turned out to be faulty flex cable that runs between LCD and the main body.
Cost me around 60 USD to fix by non-SONY service shop.Now it works like new.Worth every dime for this outdated camcorder.
Jul 22, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Jun 11, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I need the sony hc32 repair service manual
you can download a copy from: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRHC32&LOC=3
Dec 15, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony dcr-hc32 that when i turn it on i can see throuth the view finder but when i flip open the viewing screen there is no picture and the view finder goe's away. thanks
There is connecting ribbon wire between LCD board and Camera main board and this ribbon wire is cracked and needs to be replaced.
Let me know if you want to replace it at own to provide you part number.
Dec 11, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Board dcr-hc 32
dear sir
good evening,
i have bought the sony handycam DCR-HC32. cam is working in order. but there is some problems. that the red colour on LCD is off. what is the reson.
pl explain the fault & repair reson.
thanks
kamal58_asr@yahoo.co.in
Sep 15, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Driver download
pls provide Sony Handycam DCR-HC28 driver file for win xp sp3
May 15, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
May 04, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Help
You don't need cd installer! Just install SP2 and connect cam with PC USB cable!!
Jan 25, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
326 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
