Can't get the ink cartridge into my printer - Computers & Internet
Turn it around to face the other way.
Posted on Oct 06, 2008
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Please tell me how do I change the ink cartridge in my Epson TX650?
1) Looking at the front of the printer/scanner there is an indent on the left hand.
2) Lifting up on this portion should reveal the inside of the printer.
DO NOT touch the flat cable inside the printer, DO NOT force the lid, it should open easily.
3) The ink cartridge is underneath the plastic cover in the back right-hand side of the printer. Gently pull up on the cover until it swings open.
4) pinch the clips holding the ink cartridge in the printer and pull up.
5) Unpack the new ink cartridge.
6) Remove the tape that is on the ink cartridge.
(If you forget this step the printer won't print. If that happens, remove the new cartridge, remove the tape and then reinsert the cartridge)
7) Insert the ink cartridge and push gently until it clicks into place.
8) Close the cover over the ink cartridges, and then close the printer cover.
9) Follow any direction on the front display (hit OK)
May 07, 2011 | Computers & Internet
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Replaced ink in printer with generic ink cartridges and error message 1203 came up.
A person might notice that buying new, name brand, ink cartridge for printer rapidly becomes quite an expenditure. Nonetheless, there are quite a lot of different methods to find the equal quality standard for a alot lower price. Your primary options are: name brand (OEM) ink cartridge for printer, matching generic ink printer cartridges or remanufactured ink printer cartridges.
When you are purchasing a replacement photo printer cartridge, consumers do have choices. It’s frequently assumed that shoppers are required to buy the expensive, name brand, cartridge for laser printer from the manufacturer, or the service contract will become void. Their belief merely is not correct. By law, the use of compatible replacement inkjet printer cartridges does not render null and void the printer makers guarantee. In truth, you can choose to get less pricey compatible cartridge for laser printer, or remanufactured cartridges, often with a realized savings of between 40% and 75%. All chief ink laser printer cartridge brands have matching versions, including IBM, and Xerox.
Name Brand Inkjet Cartridge for Laser Printer
Nearly all major makers of laser printers also create the replacement inkjet printer cartridges that are best matched for their particular laser printers. This option is ordinarily the most expensive, and in a lot of situations it is the lone choice available if you happen to get a new laser printer whose producer implanted computer chips in the ink printer cartridge. The point of this chip may possibly be to regulate the color ink flow, limit the cartridges use, or to standardize the cartridge in alignment. Nevertheless, if you pick out a similar, or remanufactured, cartridge for laser printer, it might not be able to interconnect with the laser printer and may harm the laser copier or cause it to quit working.
Comparable Generic Inkjet Cartridge for Laser Printer
When thinking about purchasing an ink printer cartridge for your laser printer, the key aspect you must to bear in mind is the price. Buying a brand new ink laser printer cartridge will be based upon how much you are prepared to give. You can buy a new brand name cartridge for printer, or you might purchase a new compatible (generic) ink printer cartridge. Both types of ink printer cartridges might provide you with the same quantity, quality and performance you insist on from your printer. The major difference is in cost: a brand name ink printer cartridge might easily cost nearly twice the price of a compatible cartridge for printer.
Compatible (generic) inkjet laser printer cartridges are made to meet OEM (Original Equipment Manufacturer) specs. These makers usually set very lofty standards of dependability and quality and also provide high quality results, regularly exceeding the quality specifications established by the OEM. These cartridge for printer are produced with new parts and are a lower priced option to costly name brand ink printer cartridges.
Buyers might also be surprised to see that the generic comparable cartridge will publish the same amount of, or more, pages than the original OEM cartridge. Largely, this is since certain original OEM ink laser printer cartridges are not filled all the way up. In this situation, a compatible ink cartridge for printer could give you twice the advantage: it reduces your price per cartridge and cost per page by printing additional pages
Dec 27, 2009 | Dell 926 All-In-One InkJet Printer
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Install black cartridge, but will not print
Lets do it this way. Follow these steps again carefully and try to install the Ink.
Introduction
Follow the instructions below to replace the ink cartridges.
Replacing the ink cartridges
1. Verify that the unit is on.
2. Open the ink cartridge door.
3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
1 - Ink cartridge latch for the black ink cartridge
2 - Ink cartridge latches for the color ink cartridges
NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging.
6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
7. Press down on the gray latch until it clicks into place.
8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
9. Close the ink cartridge door. Print a test page.
If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
Shut down your computer and restart it.
Re-install the printer driver/software from the start as you did when you bought it.
Good luck
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
