Question about GE 24 in. GSD2220Z Built-in Dishwasher
Ge dishwasher gsd2200g02ww
On the inside of my dishwasher there is a blueish colored belt.6-8 in. dia.
Itis not attached to anything it is just lay on the bottom under the arm.
There was never a problem. Sorry about that. It was a gasket off of a lid. Silly me.
Posted on Oct 07, 2008
Gsd2200g02ww
The washing filter and disposal is in the bottom of the machine under the spray bar.
May 26, 2013 | GE Nautilus 24" Built-in Dishwasher
Water in the bottom?
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
please see the diagram attached, and test the part faulty.
May 24, 2013 | Dishwashers
I have the same groaning noise with my dish washer GSD2200G02WW
Remove both spray arms, and try a cycle with the washer empty.
If the noise changes or dissapears - replace one spray arm and try again. Replace the spray arm that creates the noise.
If there is no change, then replace the drain pump.
May 02, 2010 | Dishwashers
GE dishwasher will not drain. Does not appear to be clogged.
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Aug 27, 2009 | GE Dishwashers
GE GSD2200G02WW problem
Did you have any luck? I'm in the same jam... It seems like the piece is sealed into the tub of the washer...
Jun 23, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
My GE. quiet quiet power plus won't drain
This is normally a pump issue. check the following to combat this further..
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 11, 2009 | GE Dishwashers
Ge nuatilus wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or control board
Jun 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Water in dishwasher will not drain.
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 02, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilius Dishwasher - Water will not drain out after washing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 23, 2009 | GE Nautilus 24" Built-in Dishwasher
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. GSD2220Z Built-in Dishwasher Logo
372 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
