Question about Ovens
Oven not working
When I tur the oven on it ignites as usual, but the flame just stays low even when on full.
  • 943 Answers
Hi thanks for the question. the igniter is at fault. its not hot enough to ignite all the gas to repair replace the bake igniter thanks the appliance doc.
Posted on Oct 06, 2008
What is a glow bar ignitor
Next to the burner in the oven sits a ceramic igniter. When you turn the oven it glows orange which ignites the flame. It stays on even if the oven is at temperature and the flame if off. There are 2 wires going to it and its connectors are in a part of the oven away from the heat and flame. They do burn out. There is no reset. You have to replace it.
Oct 30, 2017 | Ovens
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why won't my gas grill stay lit?
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Dec 01, 2010 | Ovens
Oven will not heat past 100 degrees. Circuit breaker is not tripped. All other parts of the oven work fine.
Hello there:
It won't bake or even heat up correctly or If your oven won't bake, check these: Bake igniter Other causes Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
Jul 24, 2010 | GE JGRP17 Gas Single Oven
Oven won't light, even with ignitor getting red
Bake igniter
Other causes
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
May 23, 2009 | Magic Chef 9122 Gas Single Oven
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
