Question about Canon PC1061 Copier
Canon PC 1061 ADF Error
I have a Canon ADF that I bought new about five years ago and haven't used much. Only has 2700 copies on it. The ADF never really worked right, doesn't pull the paper and most times when I load it, it gives me the message to "Check Document in ADF" or "Open ADF" or something like that. Just won't pull the pages through.
The machine has always been kept clean and is in great shape with very little use, and as I mentioned has had this problem from the beginning.
Any simple fixes out there? Thanks!
  • dmfahey1 Oct 18, 2008
    I have the same problem. It just starts to pull the paper in and then jams. Have to copy individual pages on the platen glass and it takes forever.
    Problem Solver:
  • 13 Answers
Hello, you should open the ADF and try cleaning pick-up rollers + separation pad with alcohol ( some chemicals products works best but i can t remmember what kind of product it is ).
Regards, Mug
Posted on Nov 19, 2008
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Canon f80 multipass New five years ago never
Are you using Windows Vista or Windows 7? If so, the driver download page at Canon does not provide drivers beyond XP. Otherwise, go back to the XP (or earlier versions) driver downlaod site and download the MultiPASS F80 Software User's Guide. That may provide the answer to your problem. Also, if you are using unpopular, proprietary software programs the driver may not recognize the commands. Good Luck!
Apr 26, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Canon MF6530, intermittent blank copies using ADF
Its an laser shuter problems, you can say its factory error, if its under varanty call service to fix it
Feb 11, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Feb 13, 2009 | Canon PC-980 Color Copier
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON PC-1080F feeder error message
Well, open the adf and see if there's anything jammed in there. While you are at it, clean all the white out off the rollers and the scan glass. Then make sure the ADF cover is snapped shut properly
Feb 27, 2008 | Canon PC-1080F Plain Paper Laser Fax
Canon PC1061 Copier Logo
407 people viewed this question
old marine
old marine
