Question about Toshiba P000347580 - Satellite 1400&2400 Series Laptop Keyboard (P000347580KB) CD-ROM Drive
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
HI hope you can help , i've got a toshiba 1400-103 laptop & i'm trying to use the tv out & the toptop at the same time, at the moment the way its set up is all the icons are on the lapton screen & is i move the pointer in move's off my screen & onto the portable tv, what id love to do it see the same on my laptop as my portable tv, i've extended my windows desktop onto my monitor, and keep my laptop as primary, but it looks like the tv is a extecion of my laptop screen without icons ? han you help please ?
Want to connect dell inspiron laptop to show on phillips hdtv
Posted on Feb 05, 2009
    Scholar:
  • 143 Answers
Dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Posted on Jan 02, 2009
2 Suggested Answers
ahhsoo69
  • 167 Answers
SOURCE: Toshiba Satellite A45 Series won't load Windows
HELLO. THE FIRST THING YOU NEED TO DO IS . TURN IT OFF. THEN START IT UP AND HOLD DOWN ON THE CTRL BUTTON AND TOGGLE BETWEEN THE (F8,F9,F10) BUTTON'S AND IT SHOULD START UP. "GOOD LUCK" LET ME KNOW IF THIS HELP'S YOU.
Posted on Jul 23, 2008
Hi I have broke my screen on my advent 8117 I've
Try connecting the laptop to an external monitor. Power up the external monotor first then boot up the laptop and the video will automatically switch to the external monitor.
Apr 07, 2012 | Computers & Internet
Hi how do you coonect your toshiba XV55 LCD tv to your laptop
Hi you need to use either a hdmi or rgb lead to connect laptop to your tv please give thumbs up if this helps thanks
Feb 13, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How to use as monitor for laptop
i assume the TV has a VGA port (blue 15-pin) and that you're using a VGA cable.
the TV will usually have another A/V or input specifically for the VGA which can be called anything from "PC" to "other" make sure you've got that input selected
once you've got all that tell your PC to connect (button looks like a box with a line on each side) by pressing "fn" + "f4" if you have an HP...i think dell uses "fn" + "f8" i think Asus uses "fn" + "f5". (**usually if you press it once it will turn off your comp screen and transmit to tv, if you press a second time it will go back and if you press a third time it will tranmit to both at the same time)
if this is the first time you've connected your laptop to something it usually brings up a screen to configure some options like do you want to mirror the screen or use the tv as an extension of the screen.
hope this helps
Thomas
Feb 16, 2010 | Toshiba 20VL33 20 in. LCD Television
How to connect vista laptop to tube tv
If your laptop has a s-video output you can get a s-video cable that goes from your laptop to your tv's AV input.
You then just have to activate the alternative display on your laptop to make it work if it doesn't detect it automatically. Hope this helps.
Cheers
Sep 30, 2009 | Televison & Video
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
Connect Laptop to TV via USB
Hi i have only connected my laptop to the tv a few times. i did it through a scart lead connecting to the s-video-out socket on my laptop. then i when to display propertise , settings then selected screen 2, then extened to desktop monitor. it worked. i then opened a film in my player, dragged it accross, went full screen job done. hope this helps...
Nov 22, 2008 | Acer Aspire 5100 Notebook
I am trying to connect my toshiba laptop to my philips tv by vga but i do not know what settings to put my laptop on
Assuming that you have hooked the cables right, you need to press the key combination Fn + F? to activate the external video output of the Toshiba laptop. The "?" would depend on the exact model of your Toshiba. Additionally, there would be a blue lettered indicator on one of the top keys of keyboard indicating a monitor.
Incidentally, it might be worth mentioning that most TV can not operate on too high a setting of the Resolution of your Display Properties and therefore would require that the laptop's Screen Resolution be lowered down when used in conjunction with an external display device such as a monitor. At other times, the Screen refresh Rates would need to be lowered down also.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Computers & Internet
Getting m laptop on the tv screen
You should go to toshibas site. And download the User Manual if possible. this will usually be in Adobe Acrobat format.
Some laptops ( Not all ) have a certain key for example F7 Or F8 that when you start your laptop. you can press fn And F7 To switch between lcd and vga. or fn And F8 LCD-TV.
Alternatively is to re-install your operating system and hopefully this should put the system back to it,s factory default values.
Finally is to enter the bios setup, and change the initial display settings in there.
Hope this helps resolve your problem.
Mike.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
795 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
