Question about RCA Lyra RD1080 MP3 Player
Headphone jack broken, can only hear one side of headphones. how do i take it apart and fix?
    Problem Solver:
  • 12 Answers
Ther is nothing holding it together but a little of gule pop it onen but i think it is easyer to buy another one there only $20.00 or cheeper I got mine at target 5 years and that is how much thay where then
Posted on Apr 20, 2009
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
You hear one side if I move the cable to the sides and sometimes sounds the other hand I think can be a cable cut
It's a broken wire, obviously. it's probably broken near the jack or the headphone. ur going to have to replace the cable
Mar 08, 2011 | Skull Candy G.I. Consumer Headphones
The right ear phone doesn't work but the other one does
check that the wiring in the plug is not broken. if you pull the plug out a little so that one contact in the jack contacts both sides,you will hear the dead side come on. If it does not,the wire is either broken in the plug ,or where the wire goes into the headphone.
Dec 30, 2010 | Bose QuietComfort 2 Consumer Headphones
I think I have broken my headphone jack on my sony vaio VGN-CS320J because headphones plugged into this jack do not work, unless held at a certain angle, otherwise sound continues to come from the laptop...
It might be the plug on the headphone that's bad - try it on another laptop. If it's the jack that's bad, then it will need to be taken apart and that's not easy to fix - recommend having a repair shop fix it.
Dec 24, 2010 | Sony VAIO VGN-CS320J/P Notebook
Only hear out of one side of headphones with sansa player - tried 5 pairs...
i had the same problem, the headphone jack on the sansa is loose. I opened it all up, and saw that one of the connections on the headphone jack was loose. you can sauter it and it should work clearly again.
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
I can only hear out of one headphone i ve bought new headphones it just want work
Hate to tell you this, but most likely the headphone jack on your player is broken. It happens alot. If it's under warranty return it to the store. I don't believe the jack is user replaceable on this player. Try inserting the headphone jack only partway and see if you get both sides. Your cheapest solution if it's out of warranty may be to just insert the jack to the point at which you get both sides to work. It's a crappy solution, but it's probably your only hope. It's not a software problem or anything that can be fixed without tearing the player apart. Sorry for the bad news....
Aug 01, 2007 | SanDisk Sansa c140 MP3 Player
Head phone of Ipod
maybe the jack of your headphone is broken. Try with other headphones to see if you hear from the two ears.
Jul 14, 2007 | SanDisk Sansa e250 MP3 Player
RCA Lyra RD1080 MP3 Player Logo
78 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
