Question about Gateway GT5408 PC Desktop
3 beeps and fan running at start up
When I turn my computer on the tower beeps 3 times and the fan comes on. Then nothing else happens except the fan runs. The only way I can turn it off is to unplug it. HEELLLPPP!
    Guru:
  • 257 Answers
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
Posted on Oct 06, 2008
    President:
  • 1,257 Answers
How to recognize beep errors
Check out this link
http://en.kioskea.net/faq/sujet-344-how-to-recognize-beep-errors
The tower won't turn on anymore the lights are on with switch and the the different colors on the fan are on but nothing happens. ...except if you hold the front power button down all the fans turn...
If you're comfortable with it you could try re-seating the memory on the motherboard, meaning power down, unplug, and remove the memory sticks and reinsert them (use duster to clear the memory channels if possible). Otherwise I would check for diagnostic lights or beeps when turning on the computer and consult with the manufacturer for further troubleshooting.
Jan 18, 2015 | Computers & Internet
My hp envy 20 wont turn on
Need some more info:
Does the screen come on?
-What is on the screen?
--What happens when it fails?
Does a light come on the tower?
-Does a light come on in the power supply (where the computer plugs into the wall)?
Do you hear any beeping?
Do you hear any fans going?
Does the power supply fan (Where the computer plugs into the wall) try to start & fail?
-Or does it not try at all?
Apr 28, 2014 | HP Computers & Internet
Modem on and nothing on screen and fan runs loud
It sounds like one of three things. Two are pretty unlikely.1. RAM has gone bad. Really unlikely. Usually if this happens the computer will not boot but beep at you.2. Video Card has gone bad. Also unlikely. Usually the computer will sound like normal except you won't have any video.
3. Motherboard has gone bad. Most likely. The Motherboard has either suffered a voltage shock or has blown a component. The only real way to get this repaired to by going through Gateway / Emachines.
http://support.gateway.com/support/customer_care.aspx
Jan 18, 2013 | E-Machines eMachines Desktop PC
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
I have a Presario SR1950NX that is not booting. After turning on power, the fans come on and the DVD drive flickers, then nothing else happens. The keyboard and maonitor stay dormant. Normally, a loud fan...
It may be the clogged fan that caused this problem then resulted to overheat. possibly you need to replace the motherboard. or first, try using a bootable cd to boot your pc up. it may also be an issue with your hard drive not booting up.
Mar 29, 2010 | HP Compaq Presario SR1950NX PC Desktop
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
How do iknow if my motherboard is bad on my computer
Usually, by a process of elimination.
First, inspect the motherboard -- all those round towers are capacitors; any that are leaking (brown stuff) are bad news; any towers bulging at the top, instead of flat, are bad news.
If you turn the computer on, and the fans start to spin, and the disk-drive makes a bit of noise for a short time, then the power-supply probably is NOT the problem.
If you turn it on, and you get multiple "beeps", then it's either the RAM or the video-card.
If you turn it on, and nothing happens, it's the CPU or the RAM or the power-supply.
Disconnect the disk-drive, the CD-drive, the floppy-drive, and all USB devices. If you then turn it on, and you don't get a single "beep",
it's the motherboard or RAM or power-supply.
Test the RAM in another computer.
Temporarily connect a different power-supply to your computer;
if it starts properly, it's your power-supply.
Dec 05, 2009 | Acer Computers & Internet
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Gateway GT5408 PC Desktop Logo
1,516 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
