Question about Frigidaire Dishwashers
Main control timer hangs up
I have replaced the timer on my Frigidaire dishwasher M/N FDB710LCQ0 and every time the dial gets to about the 7:00 oclock position the timer hangs up. It will stay in the wash cycle forever (never let it go past 3 hours though). As soon as I advance it a little, it continues through the cycle. I thought that the timer was faulty and replaced it again with the same results. The knob is definitely not binding.
Water is not spraying through top spout and its making a weird noise...
Posted on Apr 13, 2011
Not shutting off
You don't indicate the model, but if it has a dial type timer and the unit is getting old, the dial timer motors have a tendency to weaken over time to the point where they just don't have the energy necessary to finish turning the timer any longer. The only fix at that point is either a new timer assembly (not cheap) or, and more preferably, a whole new dishwasher.
Mar 01, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher does not complete cycle
Power from the house
Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Mar 22, 2010 | Frigidaire Dishwashers
Control knob hangs
Timer has small gear pull panel off and see if gears are stripped in one spot meaning no teeth on the gears
Aug 24, 2009 | Frigidaire 24 in. FDB635RF Built-in...
I need to know how to put self timer on an L100 Samsung Camera
There is the oclock icon on the round thing that called the dial control. The flash, flower, oclock, etc icons are on the dial control. The selftime icon looks like a oclock face.
Hit it one or more than one times and the icon will appear on LCD, so your done.
Should set the selftime at higher ( 10 second some like that ) that for you have time to be in the picture.
Aug 21, 2009 | Samsung L100 Digital Camera
Dial sticks in two places until dial is moved slightly
HI. this Timer mechanism will need ot be replaced soon. the timer motor is defective. this will continue to affect the performance of this unit. replace asap.
Jun 20, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher runs several hours
OK, that several hour wash cycle seems to be very abnormal and, the only way this can happen is if the timer control mechanism is damaged. this is referred to as a Overrun error. simply replacing the timer will fix this issue.
Jun 03, 2009 | Frigidaire Dishwashers
Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Dec 10, 2008 | Frigidaire 24 in. FDBB540 Built-in...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Open Questions:
Dishwashers Logo
101 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
