Question about Tally Genicom/T.I. 8920 Printer
NO POWER FUSE CHECKS OUT OK. PLUG CHECKS OUT OK, OUTLET CHECKS OUT OK. PRINTER WAS ON AND WORKING ON SATURDAY. STOPPED WORKING SOME TIME ON SUNDAY
  • 355 Answers
These printers are notorious for the power supply going out, I bet that is your problem.
Posted on Apr 16, 2010
Need a spout plug for a juicer e-1181
Phone: 1 (973) 287-5150
English
Monday - Friday at 9:00 am till 8:00 pm EST
Saturday and Sunday at 9:00 am till 5:00 pm EST
Espa?ol
Monday - Friday at 9:00 am till 6:00 pm EST
Saturday and Sunday CLOSED
Jack LaLanne Power Juicer Official Website Exclusive Offer Buy 1 Get 1...
Aug 19, 2014 | Jack Lalanne Juicers
PIXMA MG5350 WILL NOT POWER UP. HAVE CHECKED THE PLUG FUSE.
Unfortunately, I believe the printer will need to be replaced.
If you have verified the power outlet is good, there are not many options. No reset for 'No power'.
Nov 30, 2013 | Office Equipment & Supplies
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
No power
check your adapter power is ok
check with other power adapter
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
75 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
