Power light to my DVD writer is always on and I can not open the draw. Sometimes the pc does not see the device within device manager or my computer
    Problem Solver:
  • 13 Answers
You may have a faulty drive. If the activity light is always on it is possible the lens
needs cleaning, the reason the drive will not open is that it thinks there is a disk in the
drive. What I would do is boot the pc into command prompt only, (to get the option
to do this press the f8 button as the pc starts up) then when you have a black screen
press the tray button on your DVD, it should open. WIth the tray open switch off the
PC and remove the cover. Remove the DVD drive, disassemble the drive and clean
the lens with isopropyl alcohol or Meths then reassemble and refit. Then reinstall
your O/S if you can. If you still have problems after that replace the drive.
Posted on Oct 08, 2008
I have bad dvd writer i want to diable from bios What do i have to do Laptop Make:dell Model: studio 1537 Os: vista ultimate
Access the BIOS Wizard:
Turn off your laptop. Wait 15 seconds, then press the power button to restart the system. When the computer starts to reboot, press "F2" repeatedly until you see the message "Entering Setup" displayed.
Change the BIOS Settings:
Scroll through the BIOS settings using your keyboard's arrow keys to highlight the setting you want to change. Press "Enter." Use the the arrow keys to highlight the option you want within that setting, then press "Enter."
Save changes in the BIOS Wizard:
Press "Esc," then choose "Save and Exit." Press "Enter" to exit the BIOS with your changes saved.
Note:
You can disable the DVD Writer in the Device Manager also.
Start > Type " Device Manager" and then Enter > Double Click " CD/DVD ROM Drives" > Double click on the Device > Click on the "Drivers" tab > click on "Disable" to disable the Hardware.
Have a nice day.
May 30, 2011 | Dell Studio 1537 Laptop
Burner not being read
Did it ever work?
Loose "power" cable from the power-supply to the optical device?
Does the tray open/close when you push the open/close button?
If not, it's not getting any power.
Loose "data" cable from the motherboard to the optical device?
If the motherboard cannot "talk" to it, then it cannot detect it,
and it will _not_ be present in "Device Manager".
If necessary, spend $40 to buy a new CD/DVD reader/writer.
Feb 01, 2011 | Compaq Presario sr1403wm AMD Sempron 3000+...
I have a philips&benq dvd/cd writer, and have lost the icon within the computer section and when I try to use the dvd writer it do's not operate, I have tried updating the drive but it states that my...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 27, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Sonic cannot find writable equipment on my PC
When you open "My Computer", does the icon shows 'CD-ROM' or 'CD-writer' ?
When you open "Device Manager", and expand the 'DVD/CD' branch of the tree, is your CD-writer listed?
Jul 31, 2010 | Sonic RecordNow! Deluxe 7.3
Power producer cannot find dvd writer Help!!
1st Check to see if you have power (hit the eject button on the DVD writer). If not then you have a physical problem with the drive. If external DVD then reseat the power connections from the wall and to the drive (also reseat the USB cable from both ends). If internal drive then you would have to make sure the power is plugged in well (i doubt this problem as it almost never happens on an internal drive). If you still have no power for an eject, then you will have to get a replacement drive.
If it does eject, then check the Device Manager (right click "My Computer", select properties, Select the Hardware Tab, Click the "Device Manager" button) to see if your drive shows up. There should be a plus sign or minus sign (+)(-) in front of "DVD/CD-ROM drives". Click the plus sign if you have one, otherwise you should see your DVD writer here. If there is a "red X" on the drive, right-click it and then select "enable". Then your DVD should be active.
Otherwise if you have power and it is already in the device manager, then it is a problem with your Power Producer program and you will need to reinstall it or use another program (which you can find here http://www.thefreecountry.com/utilities/dvdcdburning.shtml) Hope this helps, Best Regards, -md
Nov 14, 2009 | Acer 7720G-602G50MN C2D...
New dvd writer recognised as old
Hello.
Go to Control Panel.
Locate System.
Locate your Device Manager.
Under your DVD/CD Rom devices, locate the old DVD writer. Select it. Right click and hit Uninstall.
Now scan your computer for new hardware, and install the new DVD writer with the discs it comes with, if any.
Nov 07, 2009 | Computers & Internet
The pc wont let me burn the imesh tunes on to cd.it says error.how would i know if i have a re-writer
if the cd has been written to already, you cannot write on it again. If the cd says CD +/- R, then it is not rewritable, look for a CD that says +/- RW. If it doesn't say either of those, a regular cd looks light grey, while a rewritable is usually a lot darker.
Oct 26, 2009 | Dell Dimension 2400 PC Desktop
I need a driver to operate my gsa-4163b dvd writer.
can you give additional information why you want to download the driver for your dvd writer? try to uninstall the dvd writer in your device manager and restart your computer and the driver will be reinstalled automatically one you restart your computer
Jun 22, 2008 | Computers & Internet
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
CDRW/DVD Rom combo drive only reads CD's
the blue you are refering to is the dye on the disc, sometimes it's purple, normally the darker the better, but it's down to the individual writer and what disc it is compatable with, but your writers problem is all too common, as in my opionion the lasers that are being fitted in writers are of poorer quality than in the earlier days to enable the prices to become lower. You can try one thing, but it doesnt always work; go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays
Jun 20, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Computers & Internet Logo
David Payne
David Payne
