Question about Microwave Ovens
Sharp Microwave died after Power Surge
I have a Sharp R530 countertop microwave. The display panel had gone partially blank a few years back, but the unit continued to operate normally.
Then a few weeks ago, after a power outage, the display magically returned to normal, but the unit started acting up. While operating, the timer would continue to count down, but the unit would stop working for a few seconds (turntable would stop, fan would stop and presumably magentron too). Then after a few seconds, everything would come back on..
Then yesterday, the same thing happened, but it didn't start back up again. Now the display continues to work, but othere than the interior light, nothing happens inside the microwave.
Is this something that can be fixed with a display panel rebuild or is it more serious?
    Problem Solver:
Do you wast a lot of time tring to buy a part for a Sharp product I have all outlets including the manufacture web site or by phone are useless try these guys on this web site they know what they are talking ..Norm
Posted on Nov 13, 2008
  • Microwave Ovens Master
  • 9,098 Answers
We have the R530ES service manual for this model and have uploaded it to our site here to help you. It's close enough to the R530EK and EW models, in case that's what yours is.
You will need the free Acrobat Reader to view or print it.
Actually you have two separate problems, and both are easily solved..
(1) The reason that only the inside light comes on when you try to cook is that your secondary (bottom) door interlock switch is bad, or its mount is misaligned or broken.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order one from us for $5 postpaid or local appliance parts stores, hardware stores, or places like Wal-Mart, Lowe's or Builder's Square.
(2) The display problem is something we regularly repair these for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 07, 2008
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Sharp R-630D Display Problem
Usually switching off and removing plug for couple of minutes solves this problem if not then its going to need replacing as a resistor has probably gone on the display board unplug it then let me know what happens ok
Apr 21, 2008 | Sharp R-630D Microwave Oven
My microwave oven will not turn on.
touch panels do go faulty. Claim on the warranty.
Jun 19, 2016 | Sharp R-331ZS Stainless Steel Mid-Size...
Microwave arching
faulty microwave module replace it
Apr 22, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave is 25 years old, will it be working to maximum efficiency
If all the settings work and the door closes ok . why throw it out ?. It may not be quite as efficient power wise as a brand new one. the few cents extra to run it against the price of a new one, I would stay with old faithful.
Dec 31, 2014 | Sharp R530EWT Countertop Microwave Oven...
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
Microwave LED only displays partial numbers
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
We really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the attached photos.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jun 10, 2009 | Hotpoint JE740WY/GY Microwave Oven
Microwave Ovens Logo
261 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
