My computer crashed and i am unable to boot it. we have tried all the methods with HP suport but it failed. they say the only option is to take it to the service center, get a back up and reformat it using the recovery CD. Is there any other alternative.
    Problem Solver:
  • 5 Answers
Well if it is still under warranty and there is a heap of data you need to backup... the answer would be no.
p.s the recovery cd might have a option which will repair the current os without formatting the drives. That all depends on whats exactly wrong...
cheers
kbh
Posted on Oct 09, 2008
My HP 8020N is beeping with some blue instructions, it crashes and beebs then repeat the same thing when trying to rebooth
You are experiencing what we affectionately call "The Blue Screen of De##h", which is causing the PC to crash and reboot in a never-ending cycle. There are a few things that you can try to fix the situation. The first, and easiest, is to press the F8 key during bootup and try to go to SAFE MODE. If you can do that, then you can go to SYSTEM PROPERTIES under COMPUTER, select the SYSTEM PTOTECTION tab, and click on SYSTEM RESTORE. This will allow you to roll the computer back to a previous configuration, since it is likely that the crash could be caused by a corrupted or failed update. If you cannot get to SAFE MODE during bootup, you options get more limited. Most PCs today do not come with a Windows Installation disk, so using that and booting in the REPAIR area is not likely an option. This leaves you with either reinstalling using the recovery disk set (if you have one) or with the recovery partition. The downside of these options is that they overwrite ALL information in the disk, meaning all of your personal files will be gone. What you CAN do if you have access to another desktop PC is to shut down you computer, remove the hard disk, and install it as a second drive on the other desktop. It won't boot to the disk, so it can't crash. But you will be able to see the file structure on that disk and can recover personal files to a USB stick or other external media before replacing the disk in your system and using the recovery method(s) described above.
Mar 05, 2015 | HP Computers & Internet
Error 0xa0000001 in window
Possibly but it may be caused by many other issues.
This is from Microsofts web answer;
There are many reasons why your system may crash due to these stop errors. The most common scenarios are: Faulty drivers, Hardware issue (especially RAM) or Anti-virus software problem.
You may want to try the following and check if it helps.
Method 1:
Run Memory Diagnostics test to check for any memory problems. Refer the following link for the same.
How do I know if my computer has a memory problem?
Method 2:
Update the chipset, video card, display and network adapter drivers to the latest by visiting the computer manufacturer's website.
Update a driver for hardware that isn't working properly
Update drivers: recommended links
Method 3:
A clean boot helps to verify if any third party application services or startup item is causing this issue.
You may refer the following KB article to put the computer in clean boot:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
After the trouble shooting steps please refer to clean boot link to put the computer back to normal start up mode.
Jan 20, 2014 | HP Pavilion Computers & Internet
Macbook pro 13" crashes while booting.
Have you tried booting off of your restore disc? During startup you can boot from a CD, DVD, or thumb drive by holding "C" while booting. You can also try starting into recovery system by pressing "R" and "command" keys while booting, but I'd reccommend trying the bootable disc method first. Hope this helps!
Nov 24, 2013 | Computers & Internet
Oxeoefoooe
Method 1:
I would suggest you to check of you can open the system recovery options without using the installation disc- a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button. b. Do one of the following: If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer. If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8. c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.
c. Select a keyboard layout, and then click next.
d. On the System Recovery Options menu, click a tool to open it. Refer the below link for more information -
What are the system recovery options in Windows 7?
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 Method 2:
If the repair option is not present in the advanced boot options and you are unable to perform the recovery then in that that case there are no options other than getting the installation disc or contacting Hp for assistance.
The error code you are getting while restoring to factory settings is some error associated with the hardware for Hp computer. You might need a tool or some hardware update from HP to get over the error.
You may use the below link and check diagnostic tool update assists you resolve the issue -
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-77569-1&jumpid=reg_R1002_USEN For further assistance you may contact HP using the below provided link -
http://welcome.hp.com/country/us/en/support.html
Mar 05, 2013 | HEWLETT-PACKARD COMPAQ PRESARIO CQ5700F...
Error code on compaq presatio desktop oxeoef000e
Method 1:
Mar 05, 2013 | Computers & Internet
Are there any other methods on how to perform SAFEBOOT / SAFEMODE? I only know 2 methods which are from the F8 key on boot-up and from msconfig under the boot tab.. some say that there are still other...
There is ONE other method you can try, but do NOT make a habit of it, because you COULD damage your computer. That being said, I use this method when I have no other option.
You SHOULD be able to FORCE Windows to enter "SAFE MODE" by shutting the power off (or unplugging it) while the system is starting to load Windows. After you turn the power on, try booting the computer. The system should notice that the previous boot attempt failed, and the computer should automatically boot into Safe Mode.
Apr 30, 2011 | Microsoft Windows XP Professional
Have purchased recovery dics for my Hp TouchsmartIQ772 following massive crash! All hardware checks out fine apart from CD rom drive! Ihave loaded all three discs on my external hard drive but am unable...
Are you able to boot from CD?
When booting PC, press the Function key that lists the 'boot from' options.
Sometimes this is activated by the DEL key.
Jan 12, 2011 | Computers & Internet
I get a weird message when I try to boot up my computer. it is
Sounds like a failed windows update crashed the operating system. If Vista, boot to the Vista DVD, select the option to repair your computer and see if that will resolve, repeat running the repair process until it reports no errors.
If windows XP, boot to XP CD, press R at 1st prompt, run CHKDSK /R and see if that fixes the boot process.
If those fail, then you might have some luck with a repair of your Windows Installation from the Windows CD
Jan 11, 2010 | Dell Inspiron 1525 Notebook
My computer crashed and I cant find the cd to
find the drivers on the manufacturer's site
like of you have a hp printer goto hp.com , click on suport-drivers then download the drivers
Oct 09, 2009 | Konica Minolta PagePro 1350W Laser Printer
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
