Question about Kitchen Ranges
I have a Philips Whirlpool electric oven. My son left the interior grill on for 10 mins at 200 degrees with door closed. Now at a 200 degrees thermostat setting the oven feels more like 100 degrees and it only seems to heat from top and not also from bottom of the oven. The oven is more than 10 yrs old. Is the thermostat likely to be faulty and need replacing or will more internal damage have been done.
  • 943 Answers
Hi. Thanks For The Question. I Would Check The Bottom Element. The bake Element. Thanks The Appliance Doc
Posted on Oct 06, 2008
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cleaning racks
I assume you have tried leaving the racks in while on self cleaning mode! so as a chef also i'll tell you they have a cleaner called oven and grill cleaner, but ht eobject needs to be hot! about 200 degrees, but it will melt off anything! I mean anything!. BE carefull not to smell fumes, please
Mar 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Whirlpool oven
There is a fan in the oven, it is behind a panel at the rear.It will be a loose fan or worn bearings, or fan catching grill
Nov 09, 2008 | Whirlpool RBS275PD Electric Single Oven
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Oven door won't close tightly
Sounds like whoever installed your oven hasn't adjusted your door properly and as a result over time probley got worse? any way there should be 3 screws on each hinge the top and bottom screws hold the door in place the screws under the top ones are used for making adjustment with a Philips head screw driver open the door and try screwing in clockwise 2 or 3 full turns and with your free hand feel if the door is moving upward if so repeat the same on the other side and then close the door and see if its made a difference if so and its still loose try again if its made it worse the turn the screws in the opposite direction Let me know if this works
Dec 09, 2017 | Whirlpool RBS305PD Electric Single Oven
Fan oven door, cooker surround and hob become burining hot when using fan oven
Sounds like a problem to me. Check your oven door gasket to make sure it's intact and also that the oven door is closing completely when this overheating occurs. Although some heat will rise, it shouldn't become "burning hot".
Mar 09, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
