Question about Philips ToUcam Fun II Webcam
Aviorix when i attache the webcame to the computer the computer show one massage the measage is that windows does not recognize it
    President:
  • 8,637 Answers
Normal 0 Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Feb 03, 2009
I have a4tech webcam PKS-732G. when i attached it, the other usb ports not working properly. all other devices shows that usb device not recognized.
my laptop does not read cd.i have buy a a4tech webcam how will i instal it wheni have conect it its not detecting the webcam
Sep 05, 2011 | Computers & Internet
I have a HD5000 that was working till yesterday properly. now i receive the massage in skype that no webcam is connected. also in the HD5000-application itself i have the same massage. who had the same...
I'm assuming that you have tried a different USB socked with the same result. This has nothing to do with the software, it's a hardware fault. You can check that simply by booting from a Linux Live-Cd and see if the webcam is recognized. Most likely it has just failed.
This is unfixable, you will have to buy a new one.
Aug 14, 2011 | Microsoft LifeCam HD5000 Webcam
My computer says it can't detact my webcam. everytime I go to it, it says no wecam detected.
The first step will be to check to see that your computer recognizes that anything is detected. to do this you should:
  1. Open your Control Panel (Make sure it's set to "Classic View")
  2. Click on "System".
  3. Go to the Hardware tab and click on "Device Manager".
  4. If your computer does recognize the camera, it should show up under "Imaging Devices".
If it does not, then it should show up under "Other Devices".
  1. Right click on the camera there, and click "Update driver"
  2. Now, follow the on screen instructions, and windows should get your camera working.
If your camera is recognized, but still doesn't show up, then you probable have a problem with whatever program is trying to use it. For that, I would need to know what program that is.
Feb 26, 2011 | Logitech Webcam
How can i install microsoft lifecam 1.4? give sequence of steps.
Srikanth,
You do not need to install MS Lifecan on Windows systems. However if the system is asking you to do so or is not recognizing the webcam then you must. How?
Disconnect the webcam from the computer.
Insert the CD of drivers that came with the webcam, and allow windows to autorun it.
It will ask you if you want to install the webcam drivers. Answer yes and then follow instructions.
Once done then reboot the computer.
Attach the webcam and let Windows autodetect it and load its drivers.
If, however, the autorun does not get activated the from My Computer you must open the CD drive and run either autorun or setup.exe.
After this the procedure is the same as above.
Feb 10, 2011 | Computers & Internet
I can't do video chat with anyone because the internet cannot detect my web cam, and i can take picture with it because it never turns on, and when my PC is put to sleep when i try to turn back on it...
Hi
Very simple
Simply first restart your PC and then connect the webcam.
If the message comes again follow this
Right click on My computer-> select manage option -> a window will pop uo select device manager -> in device manager right window select USB and expand the plus sign -> you will see hare all the USB in your computer
Select the USB which is showing yellow in colour and ricght click on that -> select unistall
after that select the main USB option and right click on that and select the option scan for hardware changes
Your PC will eb able to recognise the webcam.
Jan 16, 2011 | Computers & Internet
When i plug the my pan drive with USB then my computer display such type of massage "one of the USB attached to this computer has malfunctined , and window does not recognize it"
Try to attach that pen drive in another slot and if its work fine than always use that slot.
If its not working fine or showing that malfunctioned error than please update your USB driver of your machine.
Mar 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Computer doesn't recognize CECT P168C as mass storage or webcam.
i) when u connect mobile to ur computer u'll get 2 options i) mass storage  ii) webcam , try to select any one of them
Jan 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Using GL2 as a webcam
Using the firewire/IEEE cord attach the camera to your computer.  If you are using a Mac it should instantly recognize the external camera when you open iSight or what ever utility you are using to communicate.  If you are using a Windows based computer open MS Moviemaker and it will recognize the camera as well by selecting capture -- once the camera is recognized you should be able to broadcast with it.  If you are using uStream.com sometimes your video capture interferes with the ability to broadcast.  In that case hook up the camera using firewire, connect to uStream -- grant uStream permission to capture using the camera then you can see the video in your browser window.
Oct 16, 2008 | Canon GL2 Mini DV Digital Camcorder
Problem with hp laser jet 1018
i need the windows xp driver
Jul 12, 2008 | HP LaserJet 1018 Printer
Lexmark p6350 all-in-one not working
I am guessing that you're using the New improved windows Vista. If so, you need disconnect the printer power and usb connection. then remove the current driver for the printer and down load the current driver @:http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:571:0:0
The soft ware will tell you when to install the printer
Dec 30, 2007 | Lexmark P6350 All-In-One InkJet Printer
Philips ToUcam Fun II Webcam Logo
32 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
