Question about Nokia 5300 Grey Cellular Phone
I can't access my memory card in computer although it is ok in my cell
I can't access my memory card in computer(Win XP) although it is ok in my cell (Nokia 5300)
  • Nokia Master
  • 1,800 Answers
That means taht the memry card is faulty to assure that try another one in the same operation
best regards
plz do rate thisz post as goos as u can :p
Posted on Oct 07, 2008
How do I transfer my music from my internal memory to my sd card on a LG optimus fuel LG l34c
You can do it from inside the phone. but if you have access to a computer running win 7 or later, XP doesn't find cell phones hard drive everytime, you can use windows explorer to move/ transfere files around your phone system easier and faster.
Aug 09, 2015 | LG Cell Phones
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
How to format sandisk cruzer under Win XP
Right-click your Cruzer in "My Computer" and select "Format." Select "NTFS" from the "File system" list and click "OK."
Mar 06, 2012 | SanDisk Cruzer Electronics - Others
Memory card is not working
Try the card on your PC and if not detected then it is possible that the memory is damaged. Check if there is dirt on the contact tracks, clean if needed. If not the card must be replaced. If under warranty contact SanDisk for free replacement.
Aug 01, 2011 | SanDisk 2GB microSD Memory Card
I have just got a samsung jet but can not put the soft wear on to my pc
to install your software to your pc, NPS, try to follow these steps. please take note that you don't need to connect your phone first during installation. if your phone is connected to your pc, disconnect it.
for xp operating system:
1. insert the cd to your computer...
2. enable autoplay for your cd / dvd rom drive
3. select appropriate language
4. select ''install pc suite''
5. once finished, select the finish tab
for vista operating system,
>>do the same as the above steps, if ask to run as administrator select yes.
>>after installation, uncheck run pc studio automatically after finish.
>>select install usb driver
>>click yes if prompted to run as administrator,
>>after installation, remove the cd, run NPS, and connect your phone.
>>if your phone can not be seen by NPS, do these,
on your NPS, click menu, select settings, select connection, check usb cable com1 or com 2 port select ok, and let your pc studio recognize your phone.
for windows seven, though the NPS doesn't support it right now. you can do the following tricks,
1. insert the cd, don't enable autoplay
2. browse your NPS cd, look for the setup for NPS..
3. once located, right click the setup.exe, select properties,
4. select compatibility,
5. check run in compatibility mode on win xp, win vista.
6. check run as administrator
>>during installation, if prompted that the installation was not successful it will give you an options, select install with recommended settings.
the trick also, if you can't install your samsung studio, you may do these...
on your phone, press menu,then select settings, select phone settings, scroll down and it will give you pc connections, select ask on connections, save and exit.
now, connect your phone to your computer, it will ask you what connection do you prefer, on your phone, press memory card, it will install your memory card as mass storage device, open it your my computer, you will see your memory card there, you can now, drag and drop files from your computer to your memory card.
there you go, hope this will help you so you can enjoy your jet.
regards...
Mar 08, 2010 | Samsung Jet S8000 Cell Phone
Format 32mb smartmedia in FAT12
Hi friend,
ok you can try to format on windows xp.
Follow these steps:
1.Open Control panel
2.Open administrative tools
3.open computer management
4.then click disk management
select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
ok
Regards
Uttam
Jan 13, 2010 | SanDisk 2GB microSD Memory Card
I cannot access memory card to view pictures,
try your memory card in a computer to see if it`s still working, and if it is, reset your phone to factory settings (with the card removed) and try again.
Nov 09, 2009 | Samsung J700 Cellular Phone
CyberShot DSCW55 driver wont work on win xp x64
No, their is not one if its not compatible you will have to purchase a camera that is compatible with win xp 64. Another option is to get a USB card reader ($15-$20) and put your memory stick inside it and goes directly into the usb port. You can pull your photos off just like a portable memory stick. I use this option for my Sony camera and my laptop has a media port that takes the card directly with no need to have a USB card reader....
Sep 26, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Jul 23, 2008 | Transcend (589307) Media
Belkin wireless G plus Desktop Card
Try this site and give the different drivers a go. The f5d7000 driver should work if you have tried the Win 2000 driver with no luck(although WIN ME does normally use WIN 2000 drivers in some hardware cases) http://www.helpdrivers.com/ingles/listado/panel.asp?marca=Belkin&perif=redes
Jan 02, 2007 | Belkin (F5D7001) 802.11g/b Wireless...
Nokia 5300 Grey Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
