Question about Frigidaire FEF366 Electric Kitchen Range
Frigidaire oven not working in bake setting
My oven was new in 2005 and all of the sudden it does not work in the bake setting. The top burners work and it works on broil but when I put it on bake both elements do not work. What could the problem be? I would like to fix this myself if possible.
Patty es3000 is turning the oven off before it reaches set temperature. It will also turn the oven off when you open the oven door.
  • Anonymous Nov 22, 2008
    ovI set the oven ,but it doesnt work.but broiler does work.
  • 943 Answers
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Posted on Oct 06, 2008
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
Turned the oven on and heard something pop behind the stove and realized neither of the two oven elements would come on. The top 4 burners all work. It is a Frigidaire- Self Cleaning Mod.-...
there is a chance that one of the wires has burnt to the baking element. you will need to pull the unit out unplug it and remove the back panel. and check the wiring if it is burnt you can replace the burnt part so long as there is not to much destroyed you may have to add a piece of new wire.
you can use regular but connectors and spade connectors to replace the bad parts.
Mar 03, 2011 | Frigidaire Kitchen Ranges
Broiler works fine. Range top burners work fine. Oven does not come up to temperature. It is a stainless Frigidaire Gallery.
If the bake setting is the only thing not working properly, you may have to replace that
element
Dec 18, 2010 | Frigidaire Kitchen Ranges
My oven wouldn't bake or bbroil but all burners
First suspect is the thermal fuse that feeds the bake and broil elements. It is located on the back oven wall or sometimes the top.
Jun 27, 2010 | Frigidaire FEF312 Electric Kitchen Range
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Oven Not Working
It could be the element, but if neither the top or bottom element are coming on, it could be an issue with the electronics... Have you tried any of the other oven functions? Is it a convection oven? Maybe try using the convection bake or roast/convection roast functions..(roast function doesn't go through a pre-heat cycle, I have the same stove). If it's still under warranty, I would be calling for service.
Jan 06, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I am not a rocket scientist but this popular answer is so absurdly wrong. FIRST of all read the situation correctly it states "when I put it on bake both elements do not work" that means its ELECTRIC.Duh.
Sep 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF366 Electric Kitchen Range Logo
481 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
