Washer fills, but won't start cycle, or stops in middle of cycle
My aging top-loading Magic Chef washer will fill, then either (a) not start, or (b) start, then stop working during the cycle, even though the timer continues ticking through to the cycle's end. For a while I could bypass this by monkeying forward & reverse with the dial to start the cycle, but that method stopped working eventually. This began with the Regular cycle, so I switched to using the Perm Press cycle. After a few months, the PP cycle had the same problem, so now I'm using the Gentle cycle. Any ideas re: why the Reg & PP cycles won't continue past filling? Thanks!
5 Suggested Answers
SOURCE: Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Posted on Oct 28, 2008
  • 109 Answers
SOURCE: The washer stops in the middle of a cycle filled with water.
sounds like the lid switch is faulty
Posted on Jul 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Top Load Washer Model 110.92593210 wouldn't agitate, now
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Posted on Sep 14, 2010
  • 1751 Answers
SOURCE: KAWE 6788 Washer not extracting enough water on
hi
check the filter it must be cleaned
Posted on Jan 14, 2011
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
Cold water won"t fill
check the filter... make sure the line is not kinked...
Aug 08, 2012 | Magic Chef CAV2000 Top Load Washer
Washer fills w/ water, but will not stop filling. Therefore it never goes into the agitation cycle. Any help greatly appreciated!
Level control valve is bad or line came off it or a hole in line. But it's likely the valve. It could be that you can adjust it and it will work at one level only. it has a screw where you can do that. Just take the panel off and you will see what I mean.
Ken
Sep 23, 2009 | Magic Chef CAV2000AWW Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Flooding Washer
the solenoid needs to be replaced.
Oct 03, 2008 | Magic Chef CAV4000AWW Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
