Question about Canon PIXMA MP510 All-In-One InkJet Printer
Errore codici 5100
Quando accendo la mia canonomp 510 fa un forte rumore e dà errore 5100
  • 412 Answers
Try this this,     As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Panasonic aj-d215
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 25, 2017 | Televison & Video
Buongiorno.la macchina in questione ag-dp800 s-vhs,a un problema appena l"accendo e faccio delle riprese registra con righe, ombre che man mano si riscalda spariscono per tornare tutto...
ciao!per difetto di linea di panasonic ag dp800,ho avuto steso problemo,100% sono tre filtri di condensatore elektrolitici,nella scheda video 3700[c 03/c06/c09] e sicuro dopo sostituire tutto ok,o provato io alcuni giorni fa.piu meglio e per sostituire tutti condensatori delle schede video.piu info nell mio email[avstudiosda@yahoo.com]
May 17, 2011 | Panasonic AG-DP800H Camcorder
C max 1600tdci diesel 110 cv anno 2004 errore u0101
certamente il codice indica che non c'? comunicazione tra il cambio automatico e il traction control module o centrallina
controllare il cablaggio e connettori
May 24, 2017 | 2006 Mazda 3
Scanner
Questo spesso succede quando colleghi la stampante prima di aver installato il software, o quando non installi tutto il software.
Devi installare tutto il software presente sul disco, controlla anche il cavo usb, un cavo usb difettoso puo far funzionare la stampante e non lo scanner.
Se non funziona, fai un system restore (recupero del sistema? non mi ricordo come si chiama in Italiano.
Dicevo fai un system restore da Avvio>>programmi>>accessori>>utilita di sistema...
Questa procedura riportera' il computer come stava prima che Windows installasse automaticamente i driver per la stampante.
Dopo il system restore installa tutto il software sul disco della stampante SENZA collegare la stampante finche' esplicitamente richiesto dal programma di installazione.
Se non hai il disco devi scaricare i programmi dal sito Lexmark, che pero e' in inglese, o chiedere una copia del disco al rivenditore.
Qui c'e' il sito web della Lexmark : Official Lexmark Drivers and Software
In bocca al lupo.
Nov 20, 2008 | Lexmark X2500 All-In-One Printer
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Errore F6
Errore F6 (F06) significa problemi con il motore, o con gli ingranaggi di trasmissione del motore.
La scheda di controllo della tua lavatrice rileva che il motore non sta girando alla velocita' richiesta o e' guasto.
Di solito , quando questo si verifica il tecnico controlla il motore, la trasmissione (motor coupling), l'unita di controllo del motore MCU (motor control unit), e sostituisce la parte difettosa.
Controlla questo link per avere piu dettagli su come risolvere il problema.
Non dimenticarti di votare la soluzione, possibilmente con quattro rombi azzurri.
Grazie.
Sep 03, 2008 | Whirlpool AWT5108 Top Load Washer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
