Question about HTC TyTN Smartphone
Activate GPS on HTC TYTN11
I have downloaded and installed a Run.GPS application that requires a GPS connection.
Does this phone have an internal GPS or do i have to purchase additional peripherals ?
How do i ensure the GPS is running when i start the programme?
Is the GPS connectivity to do with my mobile subscriber ?
  • tamilyn Oct 10, 2008
    Hi.. have the same problem... where does Tom Tom fit in the picture and how do I retrieve it, since according to specifications it should be loaded already.. I have an HTC TYTN II
  • Anonymous Nov 24, 2008
    It worked some time but after two repairs no activation. The manual is to brief and first did get started accedtial.
  • 30 Answers
HTC tytn II, att tilt,Kaiser ( all the same products) have internal GPS chip installed just near the camera , so you need not buy anything else. Just get google maps app, a internet connection and try to find your self by using locate me feature on google map, the GPS chip will point you on map with very much accuracy.
Posted on Oct 19, 2008
I've a htc trophy. i need pc suite for my htc can i get or download it?
Here is Download link HTC 7 Trophy Sync version 3.0 driver for connect to PC Windows. Here also give information about how to install this software. The software HTC Sync PC Suite are ready to download. Please follow the instruction bellow :
  1. Please click Download below to download HTC 7 Trophy Sync to your PC.
  2. Run file setup to install it to your PC.
  3. Follow the Install Shield Wizard to finish the installation.(Suggestion: Please close all running programs and temporarily exit your anti-virus program when you install the HTC Sync).
  4. Select the "Complete" Setup Type for faster and easier installation process, and then press "Install" to begin the installation. (For advanced users you could choose "Custom" to change the pre-defined shortcuts and the installed application folder path by your own.)
  5. After you saw the Install Shield Wizard Completed, please press "Finish" to exit the Wizard.
  6. Use the USB cable to connect your phone to the PC
  7. Now you can start HTC Sync.
May 09, 2011 | HTC 7 Trophy Cell Phone
How do you get the upgrade the htc hero to 2.1
Getting Started
Before you run the ROM Update Utility (RUU), make sure you have done the following:
  • Backed up the data on your device.
  • Standby or hibernation mode of your PC has been disabled.
  • Close all running applications on the PC.
  • Set aside approximately 25 minutes to allow the device to update.
  • Charged the battery to at least 30%.
  1. Download HTC Sync for Android.
    Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from
    HTC Sync for Android 2.0.40 (39MB)
  2. Download the Hero 2.1 MR Upgrade executable file.
    Hero 2.1 Upgrade (113MB)
  3. Connect your HTC Hero to your PC.
    Use the supplied USB cable.
    If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
  4. Run the Hero 2.1 MR Upgrade RUU file.
    Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Mar 09, 2011 | HTC Hero Smartphone
Can i activate gps maps on my instrument htc touch 3g t3232
Friend, You can run maps on any phone. If it has GPS then you will get correct position with the help of satellites and if it does not have a GPS then you will get approximate position with the help of cell communication towers. You must download google maps from That is the most fantastic maps that are available free for almost all phones. The best part is that it has Latitude feature with the help of which you and your friends can keep track of one another on your respective phones. This feature is free too.
May 15, 2010 | HTC Touch™ 3G Cell Phone
try downloading GPS Essentials (free) from the market. It has a tab that shows how many satellites the phone is picking up. that usually is what determines the gps accuracy. also remember that the antenna is at the bottom of the phone. right where your hand holds it. This should not affect it but is good to know.
Mar 24, 2010 | HTC Hero Smartphone
.net framework problem
Hi. The downloaded .msi package actually contains a couple of versions of .net (for different kind of processors). If you connect your PDA to your computer (Using ActiveSync for XP or Windows Mobile Device Center for Vista) and run that .msi package, it will automaticly detect your PDA's processor and installs the .net to your device. Hope this helps.
May 19, 2009 | HTC Touch P3450 Smartphone
I do not understand my phone enough to know how to download and use prorams fom the internet to my htc dianond back. can you assst with this?
most applications can be downloaded to your computer. then setup an activesync connection and run the setup program. the pc will then install the software onto the phone over the activesync connection
Jan 03, 2009 | HTC Touch Diamond Smartphone
HTC TyTN Smartphone Logo
659 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
