Question about Shure SM57-LC Professional Microphone
Shure SM57 Wire broken off
My SM57 stopped working. I opened it and the black wire is detached.I know which pin to solder it to on the capsule end but how do I get the wire to the XLR end? There is a filler material in the housing. So I'm wondering how to get access to the XLR pins.
Brian.
  • 4,234 Answers
On the XLR end, you should see a small screw hole. This screw is reverse threaded. In other words to make it go into the mic, you need to turn it counter-clockwise. Once that screw is inside the shaft, the XLR connector should come out. You may need to pull it out using needle-nose pliers. Pull carefully so you don't break the wires.
Dan
Posted on Oct 06, 2008
Shure mx418 stopped working
There is no fuse. The capsule may be loose (on the end under the plastic wind screen). See is the phantom power is turned off on your mixer, if it is or is not working the mic will not work. Try a seperate connection, you may have a bad wire.
Feb 23, 2013 | Shure MX418 Microphone
Have a beta 57a it wont work ? nothing
I'm assuming that you have tried the obvious stuff like using a different cable and a different amplifier?
The Shure beta 57a is a very robust and reliable dynamic microphone and there is very little to go wrong with it apart from
  1. A wire broken off inside
  2. A broken capsule - can be caused by dropping it
You can inspect for broken wires by very gently unscrewing the microphone head and peering inside - however the wiring is quite short so be careful not to pull any wires off in the process.
A broken capsule can be replaced - contact your local dealer for parts.
Feb 09, 2011 | Shure SM87 Professional Microphone
3 wires inside are detached. I do not know which is which. Help
See the SM57 User Guide. The User Guide will probably show only two wires. The third wire was used on older mics and connects to the center ground lug of the cartridge.
Dec 13, 2010 | Shure SM57-LC Professional Microphone
Is there a way to open up a Shure Beta 58A?
Once you remove the grill, there is a C-Clip that holds the cartridge down into the handle. Use some c-clip pliers to pull the c-clip out of the handle. The c-clip will remain around the post on the cartridge, but that's ok.
Feb 27, 2010 | Shure Beta 58A Professional Microphone
Shure SM57 - 3 wires:blue, red, black. Which color goes to which pin?
You need a multimeter to check this.
The black wire is customarily ground and should go to the pin that measures a dead short to the metallic case of the mike. The red and blue wires are connected to the secondary of a balanced transformer and can be interchanged with no problem.
You can get a line drawing of the mike connector correctly identified in the user guide and that can be downloaded here:
Shure SM57 manual
Nov 17, 2009 | Shure SM57-LC Professional Microphone
Reparing a Shure SM58
If your talking about the coilwires on the diaphragm, you have to be very good at soldering with a variable temperature contolled soldering station, good magnifiers and pretty much one shot a doing it. You will have to carefully remove the varnish from the wires and bridge the broken gap with more of the same diameter wire. You are better off replacing the capsule. Hope this helps.
May 26, 2009 | Shure SM58 Professional Microphone
Beta 52 not working, need wiring solution
Normally the the black wire is connected to pin 1, the white wire is connected to pin 3 and the red is connected to pin 2. Sometimes the wires on pin 2 and 3 are reversed so try it both ways.
May 22, 2009 | Shure SM57-LC Professional Microphone
Eighth in microphone jack/wire bad
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
Apr 05, 2009 | Sennheiser 100/500 G2 Series Wireless...
SHure SM57 mcorphone not working -wires disconnected
The wire coming from the switch if it has one will go to pin 2 as it is hot(+ve). Pin 3 is cold (-ve) and pin 1 is gound/shield which will make contact when the XLR connector is mounted back in the mike secured with the set screw. There should be a small hole in the side of the base of the mike that the set screw lines up with. Usind the correct size of flat bladed screw driver, back this screw out counter clockwise to secure the connector. If that is wrong, get back to me and i will hunt up my Shure wiring diagrams. If pin 2 and 3 are backwards the mike will be out of phase. Hope this helps.
Mar 30, 2009 | Shure SM57-LC Professional Microphone
Problem with SM58, no sound
Most likely cause is tiny copper windings from cartridge to the solder terminals has broken (dropped?). CAREFULLY check for a human hair sized wire leading from the cartridge to the solder terminals that may be broken. Soldering and general repair of these ultra fine wires should be performed by a steady hand and light touch. Once repaired, the capsule (element) itself should read 10-20 ohms when disconnected from the green / yellow wiring....Glen
Jul 05, 2008 | Shure Audio Players & Recorders
Shure SM57-LC Professional Microphone Logo
1,407 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
