Question about Dell Dimension 3000 PC Desktop
Auto Sensing voltage circuit
My Dell Dimension 3000 was purchased in Canada. I am now in the UK and I wish to change the voltage to 240v. There does not appear to be a switch, just 2 red squares under some clear tape. Does this mean that it has an auto sensing voltage circuit or do I have to take the clear tape off the two red squares and do something to them
  • 41 Answers
By default, Dell systems sold in Canada have non PFC power supply. Sad to say for this type of system that is pretty old it doesn't have any ATX that would convert the voltage. It's only applicable on newer systems. You might need to purchase for a PFC power supply this time since the system is in UK.
Posted on Oct 07, 2008
What voltage converter should I have to use this DVD in Canada?
Hello, Jarosaw -
Clarification: You are asking about a DVD player?
I have no idea where you reside now. If you reside in the USA and want to use your DVD player in Canada, you do not need any kind of voltage converter. Both Canada and the USA use 120 volt electrical service.
If you live in the United Kingdom and wish to use your U.K. DVD (220 volts) player in Canada (120 volts), I refer you to the information here:
https://whatplug.info/from/uk/to/canada
If you are not in the U.K., I suggest you use your favorite search engine to find the proper kind of voltage converters for electronics purchased in the country where you are located, so you may use them in Canada. I used Google with the following search strategy, using quotation marks as shown:
"voltage converter" "220 v to 120 v"
Or, you can use this kind of search strategy, with quotation marks as shown:
"voltage converter" "Your Country to Canada"
Example:
"voltage converter" "New Zealand to Canada"
Best wishes.
Dec 31, 2017 | Televison & Video
DELL DIMENSION 3000 FLASHING ORANGE LIGHT HOW TO FIX THIS PROBLEM?
This means that the computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board. You have to open the cover and locate these parts. If you are not confident then I will suggest that you take assistance of a technician
Oct 13, 2011 | Dell Dimension 3000 PC Desktop
My C drive and Backup E drive are switched
You ned to change the save path file. For a short answer...Try clicking "save as" instead of "save" there should be a dialog box prompt that lets you select where you wish to save your documents.
Jul 18, 2010 | Dell Dimension 3000 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
Change voltage from 120v to 240v sony bravia 37L4000
I think that Sony Bravia are sold with dual voltage, 110V and 220V. All 220V devices work also on British 240V network.
If an electronic device is not compatible with the 240V/220V network, then the PSU must be replaced.
In your case the unit should be dual voltage, compatible with 220/240V networks. Just ensure checking the user manual, or the tag at the back of TV.
All you need in that case is an adapter that can be purchased at any local electrical shop (eg. Curry's if you are in UK).
Regards.
Jul 26, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
What does the red switch on the back of my dell dimendion e510 do
Don't! That's for foreign voltages. It should say 115 and 230. The 115 is for 120V systems while the 230 is for 240V systems. The actual voltage you get is usually a little less than ideal, so they design power supplies to accept a lower voltage.
Jul 25, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 3000 Motherboard
You can use, the following link to replace the same
http://tinyurl.com/ycofwx
Thanks
proton
Jan 07, 2009 | Dell Dimension 3000 PC Desktop
I am moving to Canada and am taking my Compaq computer with me. Before I go I have to know a couple of things: 1. I need to get the voltage changed to 110 for Canadian power - how and where can this...
Almost all modern electronics will work on almost all power systems. Look at the fine print on the power supply (plugin adapter, brick, etc.) for the Voltage rating, which is usually 110v - 240v. On a desktop CPU, the voltage rating will be near the AC plug on the back. They switch automatically. If your DVDs play on your computer now, they'll play just fine on your computer anywhere on the planet.
Apr 22, 2017 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
110 people viewed this question
Alun Cox
