Question about Hotpoint Ultima WF860 Front Load Washer
HOTPOINT BWD129 CAN'T GET IT TO TURN BACK ON WHEN IT FAILED HALF WAY THROUGH A HOT WASH
I was washing my dog bed using a hot wash and the machine seemed REALLY hot, it had seemingly finished too. I had trouble opening the door, so turned off at mains. When I opened the door, SOOOOOOOOOO much steam came out, unbelievable. The dog bed is soaking wet and there's water in the drum still. Each time I turn it back on at the mains the on button and drying light comes on, but then all lights go off after a few seconds.
Help!!!!!!!!
This happens to me all the time. If I wash any hotter than 60 degrees is stops mid wash and the drying light comes on and when I open the door the items inside are boiling hot with loads of steam and are soaking wet and soapy. It did it to me again last night and 17 hours later it's still not working but the delay start and super wash (top 2) lights are now fixed on and I can't reset the machine at all. I've also noticed on the rare occasion that I dry things in this machine that there is no control if the heat, everything is just mega hot dry - might this also be something to do with it. The machine has been like this now for coming on 3 years and I am unable to wash any hotter than 40 degrees without the machine breaking down. It normally sorts itself out if I leave it off overnight but not this time. It's never been the same since the drum was replaced but every time the hot point repair men come out they can never find a fault. I keep telling them it's like the steam is getting into the electrics but they won't have it. Please help. Thanks.
Posted on Dec 27, 2011
  • 958 Answers
Check if you splash a lot of water specially at the center of the unit. there is this water sensor that would turn it off once this sensor is wet.
do you have any error codes?
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
My dogs bed has become rather smelly, she loves it so I was wondering how you could get rid of the smell?
The best way to get rid of bad odors is to wash or dry clean, however if it is not possible to do either of these you could use distilled vinegar vapor. To do this you need to fill a bathtub with very hot water and add 1 cup of white distilled vinegar, close all windows and doors and hang the dogs bed in there on the shower rack. The steam will rise up and neutralize the bad smells.
May 13, 2012 | Dogs
Due to a leak i have no hot water supply to the washer. I still have cold water supply can i still use the machine?
Yes provided that the wash required is not for full sterile condition you can have the cold wash using a good detergent.
Choose the appropriate program that does not have the HOT wash and it will progress the cycle.
Aug 19, 2011 | Hotpoint WMA46 Front Load Washer
Washing machine stopped working and smells like burt rubber
Sorry about that I did not notice the word "Belt" in the paragraph. The belt may be slipping. Even though it looks fine it may not be. You can normally tell if you're able to access the belt right after running it, turn off the washer and unplug it. Feel the belt or the idler pulley it's attached to. Quickly though because it may be very hot! If it is then chances are that you need a new belt. Overloading a washer from time to time can wear out the portion of the belt that contacts the pulley causing it to slip.
Oct 29, 2009 | Amana NAV5800A Top Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint BWD129 stuck in rinse phase
Problem was caused by a faulty water temperature sensor. The clue was that the owner reported increasingly hot washes, then the machine stuck at rinse. A test resistor replacing the sensor allowed the cycle to finish. A replacement sensor is on order.
Jan 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint BWD129 - Wash temperature too high
Yes you are right!
I did not mention the sensor!
If what you tell me is accurate, the sensor is the next logical part and perhaps the only one left!
I think this is it. As long as the water valve is okay!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!!
Dec 23, 2008 | Washing Machines
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
Hot washes won't start
check the hot water supply is switched on- it sounds like the valve is energising but no water is gettin through !! also check for hot water blockages. easy test is to reverse the water pipes at the back of the machine to test. tony.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
364 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
