When burning or recoding dvds i get a hardware error 0x1444d901
    Guru:
  • 257 Answers
That error should be from the DVD COMBO you are using or the system capacity or power is too low for the work you are making it doing.
ok
Posted on Oct 06, 2008
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
No burning device???
what burning software are you using and what is your burner hardware?
CHARCOIS
Aug 27, 2008 | JVC Everio GZ-MG130 Camcorder
Nero 7 burning used for pictures/video
There are many was to burn photo or dvd using nero.
The only thing you need to know is what format your dvd player accepts. If it accepts jpeg or kodack then you can burn staright to the cd.
If your dvd player hase Divx the tiy can burn any media to cd using Divx player. If not then you need to convert the file to dvd format.
Using Nero to make a dvd.
1. click on Nero and select DVD on the top middle and then click on the tab Photo & DVD
2. Then click on MAKE YOUR OWN DVD
this will open a new window here you need to select from the right hand side ADD VIDEO FILES.
3. Once loaded click next and let Nero recode the video format to dvd.
4. Insert a new dvd and burn it
This is the only way to recode a normal video file to dvd format.
Hope it works for you as its worked for me many times in the past.
Good Luck!!
Jul 07, 2008 | Ahead Software Computers & Internet
Problem burning DVDs
This happened to me also. I fixed the problem by buying new DVD discs, sometimes the mac's rom doesnt like particular discs. Its a trial and error thing with which ones it will use. Make sure you are using the latest version of Roxio toast to burn with, also make sure your ROM is DVD-R.
If all this fails, it could be your writer in the rom. Try burning a CD, if that works it will be the above problems.
Try using discs with a GOLD BOTTOM, it seemed to work for me.
May 06, 2008 | Apple Power Mac G5 Desktop
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
Burning cds/dvds
this is quite a simple matter following these instructions on this website.
http://www.8bitjoystick.com/archives/jake_how_to_burn_xbox_games_and_copy_protected_cds.php
hope this helps, maxicube
(this was a stupid question so ill give you a stupid awnser.)
(hardware is not software)
Feb 09, 2008 | Radio Communications
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
Nov 19, 2007 | Acer Aspire 3680 Laptop
Can't burn DVDs (VistaHomePrem)
Well I am not surprised ya can't get it to work.. It can all be quite confusing.... I suggest that you try some "Other" burning software. I recommend CopytoDVD...AnyDVD ... convertXtoDVD.... vso-copytodvd.en.softonic.com/ OR AnyDVD www.slysoft.com/en/download.html ConvertXtoDVD vso-convertxtodvd.en.softonic.com See one has to have a program that will "Burn" in a Format suitable for ALL players PC & stand alone DVD's the ones I have listed Just work... ensure you read the "Help" files and B4 long ya will be watching DVD's.
Sep 05, 2007 | Toshiba Satellite P105-S6207 Laptop
Computers & Internet Logo
David Payne
David Payne
