Question about JVC Cameras
Sir My JVC Cam Card was fallen in water, on showing to a local repairer he says its mother board has been damaged and to be replaced.Where can i get it.I am residing in Hyderabad Andhra Pradesh India
DJYar
  • 41 Answers
SOURCE: x box not turning on
Sadly, the original Xbox power supplies are rather weak against overloading. I personally know of 3 systems which died due to power issues. I really wouldn't suggest repairing it unless you have someone who really knows what they are doing.
Posted on Aug 23, 2007
  • 3 Answers
SOURCE: Disc not recognizing
Does your dvd match the reigon of the player? If you are using a homemade dvd then check if it is a dvd-r or dvd+r. Your player may support the other.
Posted on Jan 01, 2008
  • 212 Answers
SOURCE: Authorised service center in Hyderabad, India
+(91)-(40)-66048356----call this number this is the service center number for polaroid digital cam its located in :Secunderabad, Hyderabad-500003
Posted on Jul 03, 2009
caroldon
  • 17130 Answers
SOURCE: SIR my hadycam is not
Even if there is one , it depends on whether the centre is equipped except for minor issues.
so check with your regional service dealer
India <91> ADONIS ELECTRONICS PVT. LTD
URL: http://www.onida.com
Email: support@adonis.co.in
Ahmedabad Plot No 447/2/A, Opp. Mangal Vidhyalaya,
Opp. Textile Bank, Nr Mithakhali circle, Elise Bridge, Ahmedabad-6
TEL: 079-3988 9000 / 3294-2148
Bangalore No. 488, 5th "A" Main 11th Cross.
WOC II Stage, Mahalakshmipuram BANGALORE - 560 086
TEL: 080-2319-5539 / 3292-8265
Kolkata (Calcutta) 70,BECKBAGAN ROW, G/D BECKBAGAN MORE
N/L METHAI & CESC GODOWN KOLKATA 700 017
TEL: 033-2289-6221
Chennai ONIDA HOUSE, 18, 4TH LANE, OFF. NUNGAMBAKKAM
HIGH ROAD, NEAR C.A. INSTITUTE, CHENNAI-600 034
TEL: 044-2833-0220 / 3293-1522
Cochin BLOCK A, THARAKANDAM ESTATE, KURISUPALLY ROAD,
RAVIPURAM, COCHIN-682 015
TEL: 0484-2357-536 / 3259-353
www.jvc.co.in
Posted on Sep 28, 2010
bayyagg
  • 1672 Answers
SOURCE: i am facing a problem
Dunno about India, but surely u forgot to replace/check the DiODE when replacing ur IC!
Posted on Nov 18, 2010
My jvc hd led tv is showing dark faint picture.how do i correct it.is there any jvc service provider around durban south africa
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 22, 2017 | JVC Televison & Video
Vertical lines is shown on screan
Hook a spare monitor to the pc, if picture okay! the JVC monitor will need to be replaced, "main circuit board mounted on back of the LCD is failing" not cost effective to repair, cheaper to replace. But if both show the same symptom it is the video graphics card, in the computer.
Apr 23, 2012 | JVC 6871l-4420c, Lc420/lc470wun-sba1...
Good picture no sound
Hello
Check the speakers first. Get this set connected to an external audio amplifier device, such ans an amplifier or so, with its audio out connections at the back of the TV with audio in connections on the back of the amp, and listen whether you can see sound from the external amp. If you can hear sound from the external amp, and not with the internal speakers of your tv, either the speakers may have damaged or it audio output IC had got damaged. if so you have to replace the IC or should replace the audio card o your tV, if the IC is not available at local electronic spare part market.
If you can't hear any audio by external amp, as it has been connected as stated earlier, the mother board [main board] of your tv has the trouble. There is no repair to this digital board, and it should be replaced as card basis. OK.
Feb 08, 2012 | Vizio 42 in. LCD TV
Dear sir , photoprints from my camera shows parellal lines when the picture is zoomed the lines becomes bold from...
This is can be due to sensor damage or memory card damage.
  • Card damage (maybe repairable).
This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera.
To check whether the damage is on the card or on the camera, copy a good picture from your computer and check it a few days later with a COMPUTER. If the lines appear on them too, you can say that the card is damaged.
If you want to try to use the card again, You can try formatting it (method differs from cam to cam, check instructions manual for specific instructions)
If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
  • Sensor damage (unlikely to be repairable):
If you pointed the cam directly at something very bright like the sun (for taking pictures of an eclipse for instance), some parts of the sensor will get burnt. In this case you will get oddly colored dots all over the pics in the same places.
Parallel lines are consistent with other kinds of sensor damage like because of water.
I'm afraid that you might not be able to find someone to repair this cam; it's not a professional DSLR camera. which means repairs to it can cost more than buying a new camera will!
May 02, 2011 | Canon PowerShot A470 Digital Camera
MY PC Desktop won't boot up, in the back off the tower a clicking green is blinking ,and on the motherboard is also a green light blinking ; i think it is the power supply What i did before this was...
First of all this might sound silly but when you say (turn it back on disconnect my old graphics card on safe mode) did you actually pull out the graphic card from the mother board while POWER WAS ON??? if so you definitively damaged something (the mother board or the power supply) to check you could try an other power supply if it still wont work than it's the mother board, now if I've miss understood your question it sounds like a SHORT CIRCUIT somewhere on the board check for lost screws that could have fallen and running loosely on the mother board while changing your hardware...
Hope this helps!
Feb 09, 2011 | Sony VAIO VGC-RB43 PC Desktop
My laptop video card damage totally some repair shop said their is no chance to repair or replace.the whole motherboard must be replace.tnx.
well you have to buy a new mother board.because unlike like the desktop the VGA card is built on the motherboard so you have to change the whole board.
Jul 12, 2010 | Computers & Internet
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
D630. LCD and external monitor does not display.
If its integrated and damaged then You would have to replace the mother bord (pricey)
have You tried reinstalling the video driver?
Alternative would be to get an external video card if rest of the mother board is ok
Jul 18, 2008 | Dell Latitude D600 Notebook
Cameras Logo
32 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
