Question about Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
Lost: the rubber ring at the bottom of the bagless canister!
Inside the bagless canister, there was a rubber ring that sat at the bottom. In emptying it, I think it fell in the trash. The only change I have noticed was that the vacuum seems louder than usual now and the Hepa fiter keeps popping out during use. I don't know if this ring has an effect on the efficiency or suction of my vacuum, but the problems have been pretty annoyingt. The round, black rubber ring went over some tiny holes at the very bottom of the canister. Can I get another one? Is it even important? Any suggestions or solutions would be greatly appreciated. Thank you for your time, Kelly
    Genius:
  • Hoover Master
  • 2,382 Answers
Order a new one.
Good luck
Mai
Posted on Apr 12, 2017
  • 7 Answers
SOURCE: eureka 4700a bagless vacuum
I'd check the hoses again and see if there are rips or leaks. If it has a seperate motor for the suction, I'd make sure that it works.
Posted on Nov 21, 2007
reddevil6
  • 1673 Answers
SOURCE: F6055-900 SteamVac Maxextract LS
Might just be a bad sensor, or it is coated over with dirt. If the tank lid has one of those round filters on it, make sure it isn't pushed all of the way up to the top, needs to have a 1/4 inch gap.
Posted on Jan 06, 2008
SOURCE: Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
I had the exact problem. Here's what I did and it now works fine.
1) Remove and empty the dust container.
2) Remove the cover on the side of the dust container of the round space by pulling it straight out.
Mine was totally clogged. I just need to remember to do that periodically.
Hope this helps.
Posted on May 26, 2008
SOURCE: Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The model DB9191 is equivalent to the model CB9191 made by the Clean Bloom Electric Co out of China. So if one can track down the replacement HEPA filter for it ...
Posted on Sep 07, 2008
My dc05 gathers dust and pet hair in the filter at the top of the cylinder and does not pass into the cylinder. I have replaced the filters and the sponge.
you have lost the rubber insert at the bottom of the canister. The bottom of the center cone normally fits into this and blocks the bottom of the cone. It would have fallen out when you emptied it.
Aug 06, 2010 | Dyson DC05 Cylinder Bagless Canister...
Vacuum sounds funny and doesn't have any suction.
I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have lost suction.....what do I do? -with the vacuum and the hose!
Its okay to unscrew where the hose is connect to the area close to the bottom, where the hose bends. That is where there is usually a ball of hair, dust, and whatever. Pull the hair ball out and also clean the roller.
Jan 12, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
On the DC07, the entire cyclone assembly must be removed to empty the dust, debris, etc. collected when vacuuming. On the top of the cyclone is a "trigger" that you lift with your finger to release the...
Beofre you go to the extent of buying a replacement canister, you can remove the top and using a straightened coat hanger type thing open that bottom lid. Then maybe you can clean the rim and possibly add some silicone spry to loosen things up. Here's how to get inside In this order: 1) Remove the canister 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Use a straightened coat hanger and with a flashlight to guide you, reach down with it and push it into that hole down at the bottom center of the canister. That will pop the lid open. Clean the canister & lid rims, maybe add some silicone. At this point you might as well clean the canister too. OPTIONAL-> ***leave the bottom lid open*** and follow the rest of these steps 4) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lack of suction
you should check the round filter casing on theleft and the right side of machine to make sure they are snaped in right also the clear hose on the bottom sumtimes comes unhooked.
Dec 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have checked the machine for blockages, none found.However, the machines turns off after running for about one minute. Any ideas?
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Dec 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson seems to have lost suction?
If the usual clog clearing and filter cleaning doesn;t work-> I love the Dyson (DC07), but after 7 or 8 years it lost suction and needed some attention beyond filter cleaning. After much online research I found the few bits of advice that for me were the holy grail. After all of the standard stuff, clear clogs, clean filters etc..... In this order: 1) Remove & empty the canister, ***important****-leave the canister bottom lid open. 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Nov 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Doesn't seem to have as much section as when new. Is there some routine maintenance I should be doing?
Nov 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Bissell TurboForce Bagless Turbo Brush doesn't work
clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Sep 07, 2009 | Vacuums
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner Logo
67 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
