Question about Belkin (F5D5231-4) Router
Cant access network laptop and router settings do not match
  • 63 Answers
Check the ip address of the router and access it through IE.
Posted on Oct 06, 2008
The settings on my laptop do not match settings on router or access point and i cant get them to match i am very computer illiterate
Goto start>network>network and sharing center>manage wireless networks. In there delete the old one and then try to connect to the router again.
Mar 28, 2011 | Linksys Computers & Internet
My belkin has an orange color and i cant connect to my laptop because it has an red X saying the settings saved on this computer for the network do not match the requirements or the network Please help!
Hi lil_dreamer,
The Reason why you have that message is because the Network Key on the Router did not match the Network Key that you've entered on the computer to fix this you need to access your Wireless Settings Page and check the Network Key after that we will remove the same settings on the computer and add a new one.
To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can change the security type of your rotuer to WPA, WEP or you can also Disable the security. Personalize the Passphrase or Network Key so that you can easily remember it.
Now that we have the information needed lest configure your computer.
- Click on Start or Orb.
- Click on Control Panel.
- Select Network and Sharing Center.
- Click on Manage Wireless Networks on left under Task
- Remove all the Saved Networks on the list.
- Click on Add.
- Select Manually create a network profile.
- Enter the Network Name (SSID), Select the Encryption Type (WPA,WEP,WPA2), Enter you Passphrase or Network Key.
- Put a Tick or Check on Start this connection Manually.
- Click on Connect. Wait for the confirmation and it will work fine now.
Don't forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
When logging in, it will not accept my passphrase?
If it doesn't accept it then it doesn't match what was setup in the router, login to the router via a browser at 192.168.0.1, using a ethernet connection. Find the Security Settings page and check the spelling for the passphrase entered there, take note of the Network Authentication that is setup also, when accessing the router from a laptop or pc the network authentication and passphrase must match.
Jun 10, 2010 | NetGear WGR614 Wireless Router
Wireless card on packard bell laptop not working
I believe your problem is the network key, you changed it most likely. And you are now locked out of the network. The "key" in your computer must match the "key" in the access point (wireless router). WEP is a security protocol that runs on the wireless link. The 169 number tells me your wireless adapter can not create a link between it and the wireless router. So you are not connected. You'll need to get the "key" from the wireless router. Try entering 192.168.0.1 (that a guess on my part as to the number, generally this is the gateway address) as a web address on your desktop and look at the security settings in the wireless router.
Or else, restart the router and try to connect it again.. Anyone of this should work
Apr 20, 2010 | Computers & Internet
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
I just cant recieve internet signal alhtough all of the cords are in the right spot. Im not setting it up right on my computer my network is telling me that the saved settings on my network do not match...
You can access your router's programming by hooking straight up via ethernet cord, and typing 192.168.1.1 If it asks for username and password, type admin for both. Make sure internet settings are all set to automatic settings and no proxy if you are using cable.
Sep 10, 2009 | Belkin F5D7234-4 Router
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot access the internet
try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Belkin (F5D5231-4) Router Logo
18 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
