Question about Ricoh Caplio R7 Digital Camera
Ricoh R7 'unmatched files'
Recently I've taken pictures on my r7 and when I go into playback mode the screen is grey with 'unmatched files' appearing on the LCD screen. It's happening to older photos on the card now. It's not the SD card because I've tested it on three different cards. The camera is two months old so what could be the problem?
  • Anonymous Nov 26, 2008
    Same thing is happening to me. Although when I take new photos I can see these, but can't get to see the older ones through the playback mode.
Hi I really need help with my Richo R8 Camera. I have had problems with it since I bought it. Each time I try to put files onto the computer (not evry time) but I may veiw the files or copy them into my pictures on a computer then later I turn on my camera an look at the photos and the ones I veiwed or copied on a computer are Unmatched files and they look grey. It doesn't even recover if you go into settings and recover file it says "there is no file to recover' PLease help me coz now i have great memories lost! Its really frustrating :( later
Posted on Nov 03, 2011
It appears that if you connect the camera to the pc and then rotate the image directly on the card (which is in the camera), when you try to playback, you get this error. Easiest way out is to copy the file from the camera to your pc and then make the necessary changes.
Posted on Oct 01, 2009
It could be that you've used the SD card in a PC/Card reader etc? I've had a similar problem in the past, but so long as I reformat the card every time it's been in my PC, it seems to be ok. However, it also seemed to be more the case with cards that had been used very frequently, so if you say you've tried a few cards, I could be wrong - but might suggest giving the re-formatting thing a try anyway to see if that helps.
Posted on Aug 09, 2009
  • zmt1981 Aug 10, 2009
    I should probably have added that reformatting the card will delete all data from it.
My Ricoh R7 doesn't take any pictures any more. It doesn't matter what sim card i put in it says" card is write protected" What can I do?
Hi!
That is not actually a SIM card. It is a memory card. You have to take it off from the camera and then look for a small switch on the side. You have to move it the other way around to unlock the memory card.
Let me know how that goes.
Jan 02, 2011 | Ricoh Caplio R7 Digital Camera
Caplio R7 Lens having black spots
Sounds like the spots are on your sensor. If on the lens, it would be too out of focus to matter.
Jun 09, 2010 | Ricoh Caplio R7 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
My Ricoh Caplio R7 won't recognise the SD card anymore (and only saves to the limited internal memory). I've tried other SD cards and they don't work either.
1. Go into the menu and scroll to "reset"...follow the on-screen instructions. 2. With the memory card out of the camera, go into the menu and scroll to "format"...follow the on-screen instructions.
3. If the pictures from the card are safely on your computer, format the card in the camera. 4. Be sure the slide switch on the side of the card is in the unlocked position.
Nov 26, 2009 | Ricoh Caplio R7 Digital Camera
My ricoh caplio r7 has developed a fault with the images it captures.they now appear as muli imagea of the same picture.They look as though i have taken the pictures through a vernitian blind.In that they...
If the images are okay in the camera but not on the computer, connect directly to the computer with either your camera or card reader. If you're using a USB hub, bypass it. Plug directly into the computer instead. A USB hub will sometimes scramble a picture file.
Aug 10, 2009 | Cameras
Ricoh R7 Lens Jammed
you would love to see what was the truth as link following,
http://xiaolaba.wordpress.com/2009/04/25/camera-ricoh-caplio-r7-a-real-****-lens-error-00-00-00-30-02-23/
it was a **** design by RICOH, sent your message of compliant to them. you may get free service.
Jan 25, 2009 | Ricoh Caplio R7 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Camera lens won't close says error 00000
This is a known problem, they wont easily admit it but we had 2 R6's and an R7 with the exact same issue. If you look on ricoh site they had a firmware patch for the R6 to try and fix this issue but it dis not work.
Lady at ricoh UK admitted there is a design fault with the Ricoh R6 and R7 and she sent me an R8 which has a whole new redesigned mechanism.
Dont let them sell you useless kit, get a replacement free of charge or complain.
Jun 20, 2008 | Ricoh Caplio R7 Digital Camera
"r7" Error Code
If the camera works OK, then the r7 means that you have room in your memory buffer for 7 more pictures to take ("remaining 7"). As soon as you take a new picture, it gets transferred instantly to memory compact flash memory, and again r7 will display. The instance when there is r6, r4, etc. is short lasting, that you would not notice. Change you camera setting, let say for small size JPG, and you should see that many more files will fit in the buffer, as indicated by a larger number after the letter r.
Sep 14, 2005 | Nikon D70 Digital Camera
Ricoh Caplio R7 Digital Camera Logo
210 people viewed this question
Top Ricoh Cameras Experts
pictureman4u
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
