Question about Sony VAIO SRX99 Notebook
Mark in lcd so i want to view in vga other moniter which cable i should i use
I have a mark in the lcd screen and its geting bigger so i want to use in vga mode in other moniter so what is the cable required to see in other moniter
  • montu raju Oct 06, 2008
    no its present in laptop its has only one square like connection
  • Sony Master
  • 1,250 Answers
Connect through the vga port of your laptop to the monitor, the cable is present on the monitor itself
Posted on Oct 06, 2008
Screen keeps turning BLUE
Check the VGA cable of the Moniter and if cable is OK then will have some problem on LCD
Oct 08, 2013 | Computers & Internet
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have an HP Pavilon, Laptop and an Acer Monito
you can buy a lcd cable to connect your laptop and your acer moniter.
if your moniter is a crt then no need to buy you can use the default cable.
if its a lcd the cable is given in that package. you can use it.
you can see a vga port in your laptop with blue colour that is the connector for moniter and your laptop
Jul 14, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
Flat screen zenith Z20LCD1 use as a moniter HOW? Thanks
this is from the manual:
When the input source is PC (Only for Z15LCD1)...
PC S ettup ((Z151L5CLC1RD1
1. Set the monitor output resolution on the PC before connecting to the TV.
2. Connect the TV to the PC with the PC cable.
3. Connect the PC audio output to the TV's PC S OUND input.
Viewing Setup
1. Turn on the PC.
2. Use the PC b utton on the remote control to select PC .
it appears only the 15" model may be used as pc monitor
Dec 06, 2008 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Pinkish Color on Monitor
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Jun 09, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Sony VAIO SRX99 Notebook Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
