Question about Acer TravelMate 2300 Notebook
Price check on acer travelmate 270
Hi i have an acer travelmate 270 the screen is fine it has a 40 gig hard drive 1 gig ram i think the problems are on the usb ports only 1 of them work the touchpad works to move the curser but the buttons to click dont work so i have a usb optical mouse with it and the battery dosnt work so it always has to be plugged in which i was going to fix and with the usb port i was buying an adapter so i could have more plugged in so when i have all this how much will it be worth?
  • Anonymous Oct 06, 2008
    wifi
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    Trying to add ram
    Take them both out and reboot, you should get a beeping sound which is basically telling you it has no ram.
    Then put 1 stick back in, and reboot. If it doesn't boot, take it back out and replace it with the other stick. If it still doesn't boot, try an original stick of ram if you still have them.
    you could either have faulty ram or ram that is not compatible with your travelmate.
    Regards
    Mike
    May 27, 2010 | Acer TravelMate 2480 Notebook
    Acer Travelmate 270 Memory Upgrade
    Acer TravelMate 270 upgrades:
    The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
    The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
    Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
    You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
    Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
    You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
    The laptop absolutely flies with these upgrades.
    Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
    Sound problems with acer travelmate
    Check the balance settings in the Volume Properties. At the bottom right of the screen you should see a Volume icon. Right click and select 'adjust volume properties'. In the box that shows up, adjust the slider bar to middle under the 'Balance' column.
    If that does not work, then there could be a defect with the internal speakers. Since you only just bought the laptop, you should be able to get it replaced under warranty.
    May 19, 2008 | Acer TravelMate 4072WLMi Notebook
    Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
    Upgrading acer laptop RAM
    You Can Actually Upgrade This To 2 Gig Memory.
    Each Slot Will Take 1 A Gig Strip.
    I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
    Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
    You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
    Mike @ Compurepair.
    Feb 28, 2008 | Acer TravelMate 2500 Notebook
    Memory
    The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
    This information can be found on Acer website.
    If this solves your problem, please mark this as Solved.
    Thank you
    Oct 12, 2007 | Computers & Internet
    Acer Travelmate 291LCi problem
    how much free space left on hard drive? also check virtual memory settings and finally run scandisk and defrag on hard drive.
    Jun 07, 2007 | Acer TravelMate 290 Notebook
    Display problem on acer 270 trvel mate
    It could be a faulty driver, hopefully and not your screen, download driver from here:- http://support.acer-euro.com/drivers/notebook/tm_2200.html
    Feb 18, 2007 | Acer TravelMate 270XV Notebook
    Computers & Internet Logo
    66 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
