Question about Asko T741 Dryers
Asko T741 - Thermostat keeps cutting out
My condenser tumble dryer has worked fine for 4 of the past five years then despite having an engineer around a couple of times, it keeps cutting out, often within ten minutes of starting the load.. I then have to pull the machine out, press the reset button and wait ages for it to cool.
I have tried all the usual things such as cleaning the filters and cutting the load size. It is located under a counter in the kitchen but is adequately vented as it's worked fine fo four years.
I have noted the following: When the drier turns off, the washing is usually steaming and very little water collects in the water collection tank. Is it possible that the condenser is broken or is there a pump that pumps the water up to the collection tank that could be broken ? If there are checks I could do for this, I'd like to know.
Further, as the next step is to chuck the machine out and start again as I am disillusioned with expensive repaimen who haven't fixed the problem, can anyone tell me where I can get a techical manual for this machine so that I can have a go myself, please ?
  • cbbc Nov 14, 2008
    I have the identical problem - the machine worked absolutely fine for the first 4 yeears, then began to cut out occasionally. Despite having numerous engineers look at it, a new condenser and a new thermostat, it now cuts out every 10 to 15 minutes. As it's built in, it's a real pain to get to the reset button at the back. I now have the machine in the hall, whilst I try and decide whether to give up on it or buy a new one.
  • Anonymous Feb 02, 2009
    I have the exact same problem as described above. It started after 4-5 years of operation. Wish someone had a solution...
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Posted on Apr 18, 2009
Check sensor for fluff. We have asko tumble drier and have had to clear this of fluff many times. Take bottom panel off, as if removing filter to clean. Located on left hand side is a plastic cover, grey, secured by one security head screw. Once screw is out carefully remove circular cover uncliping clips. Inside is a sensor with a plastic cage around it, about size of one pence piece, clean fluff out with toothpick for example. This should do the trick. Good luck.
P.S State the obvious, but make sure the pull out box filter is cleaned with a good wash through with water and not clogged!
Posted on Feb 16, 2009
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
My tumble dryer isnt heating up
bad element or thermostats , check for continuity with multimeter, the thermal cut off and the hi-lo thermostat. Its electric right? if Gas need to check Flame igniter, glo bar, condenser coils, additionally
Sep 13, 2014 | Indesit Dryers
Why does my tumble dryer switch off after five minutes then switch back on after five minutes and repeats ?
CHECK CONTROL BOARD? AND CYCLING THERMOSTAT OR THERMISTOR, EVEN CHECK UR HI-LO AND THERMAL CUT OFF THERMOSTAT
Sep 11, 2014 | Dryers
Why is water not being pumped from condenser to container?
in the back of the condenser there is a small resevoire and a water pump that has a float and a switch be sure those are all working
Jun 22, 2014 | Asko T741 Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Hotpoint aquarius tdc32s not heating up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
Asko Drier T741, Panel powers up, Press start Trips House Circuit
yes time for a full service take to your nearest electrical service place
Feb 22, 2009 | Asko T741 Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Asko T741 Dryers Logo
625 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
