Speedtouch modem settings will not retain password. have to enter passwoed each time before internet will connect.
    Guru:
  • 257 Answers
Anytime this occur is the problem taht always occurif the CMOS battery is down or does not have the power to function properly again what you are going to do is to change the CMOS battery with a new one so that you can enjoy your system an you wount be boddering yourself repeating the password everytime you want to loggin again.
ok
rate this solution
If the modem still work the same then there is a problem with the modem and that is another problem that user guide can easily explain or you contact the product website and loggin the complain
ok
Posted on Oct 06, 2008
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually http://192.168.0.1).
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 05, 2009 | NetGear DG834G Router
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
Synchronizing dsl failure with speedtouch 330 on Vista
you can download speedtouch installation drive for (windows VISTA) from www.speedtouch.com
Feb 03, 2009 | Alcatel Speed Touch USB (3EC18607GA) Modem
Connecting a thomson speedtouch 858v6 modem to wireless
open the web browser, type in "10.0.0.138" without the quote in the address bar, press enter. that should bring you the the log in screen of the speed touch.
type in "admin" with password of "SpeedTouch" S and T are capped.
to configure the DSL go to the following link and select the configuration you are look for.
http://www.grandecom.net/site-file.php?fid=37
Jan 29, 2009 | Alcatel Speed Touch Home Modem
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Buffalo airstatio whr-hp-g54 router unable to connect to Orange speedtouch
I think the speedtouch modem do you have is a usb modem connection. The best solution is to call your ISP provider and request that you need to replace the usb speedtouch modem to LAN or RG45 connection. But the only problem you encounter if the internet you applied is personal only sometime they cannot provide the LAN connection to personal connection (like globe ISP).
Apr 08, 2008 | Computers & Internet
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
Speedtouch username and password
i need user name and passowrd for modem speed touch
Nov 12, 2007 | Computers & Internet
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
David Payne
David Payne
